Question about Poulan Pro 22" Self Propelled High Wheel Mower
My poulan pro 650 series lawn mower won't stay running what could it be?
  • 86 Answers
SOURCE: my lawn mower will not stay started
Since it starts, it doesn't sound like an electrical problem, it sounds like it runs out of air. To test this, remove the air filter, start it and see if it stays running. If so, replace the air filter.
It could also be varnish or sludge in the carb bowl. This is best serviced by a technician if you have little mechanical prowess.
After sitting for 3 years, I would at minimum do all of this before I expected it to run ok:
  1. Change the oil.
  2. Replace the air filter.
  3. Drain the fuel tank by removing the fuel line from the engine end (not the tank end).
  4. Replace the spark plug.
If the above did not work I would drop the carb bowl and clean it, then add one ounce of carb cleaner to a full tank, and let it run (roughly if necessary) through the engine.
After sitting 3 years I would also replace the fuel line itself!
Posted on Mar 29, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
heres2maine
  • 84 Answers
SOURCE: how to change oil in poulan pro 650 series model
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Posted on Apr 15, 2010
rycgl
  • 1545 Answers
SOURCE: Why is there no manual for Poulan Pro lawn Mower
This site has a lot of manuals submitted by users:
http://www.manualsonline.com/
Maybe you have/haven't checked this site. Maybe a user has NOT submitted any manual for your exact model on the sites you have chosen. Please repost stating what REPAIR help you need and hopefully someone on here will respond.
Posted on Aug 29, 2010
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Poulan pro 650 model#96142003403
the easiest way is to run it out of gas and turn the mower on its side with the dip stick tube on the lower side and drain it from the dip stick tube
Jun 30, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 550 will not stay running. Changed diaphragm and gasket with no improvement. New gas new plug.
Double check the muffler and be sure it isn't stopped up by what we call dirt dobber nest here in the south. I had a string trimmer once that did the same thing and that was the problem.
May 02, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
How to change oil in poulan pro 650 series model hp-22 mower
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
955 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
