Question about Linksys Wireless-G WRT54G Router
Trying to add a laptop to my home wireless router and it will not recognize it
  • 22 Answers
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the
adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card
and try to connect (instead of the software provided by the card manufacturer to control
the device)
Once confirmed that the adapter is installed properly - Now try to search for networks
This should solve your problem..
Posted on May 11, 2010
did your run the router software on the new computer? Give it a try.
Dont have it? Go to www.linksys.com/support
Apr 29, 2010 | Linksys Wireless-G WRT54G Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Trying to add new laptop to existing system and wireless printer is not recognized by laptop
what is your current wireless access point/router? is your printer an IP printer? what are the brand and model of your laptop, printer?
Sep 04, 2009 | Computers & Internet
Adding wireless printer to thinkpad T43
If you have a wireless router, the printer will talk to the router and not to the thinkpad. You would have to establish a connection between the printer and the router. Then share the printer to print.
If you dont have a wireles router and you are trying to connect your thinkpad to the printer directly, the wireless card in the thinkpad should be in the adhoc mode. ( See Wireless card properties )
Hope this helps
Thanks
Ranjit www.supportminds.com
PS: Dont forget to rate me if you got your answer.
Aug 13, 2009 | IBM ThinkPad T43 Notebook
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Trying to take a new wireless built in laptop, home to my current wireless network. The new laptop recognizes my home wireless network, but unable to connect to it. The laptop is a Dell studio 17 and...
If you are hardly doesn't connect even your wireless station is been detected why not try to set your settings manually in your wireless card.
This is when you are behind a router.
Goto Network and sharing center. Click on Manage Wireless Network. Click on Adapter properties. Click Internet Protocol version 4. Click properties, then set the ipaddress of your laptop it doesn't have to be identical to any of your existing connection, your subnet, default gateway. And also input your IP DNS.
May 18, 2009 | Computers & Internet
Need to add another laptop computer to my wireless router at home
Try (admin) for your password and see if that works for you. Good luck.
Feb 18, 2009 | Linksys Wireless-G WRT54G Router
Internet radio will not connect to recognized WiFi
Try going into your router configuration menu, and opening the network so that any device can connect. Disable any passwords and all of that, and see if it will connect in that way. This doesnt sound like a problem with the Stiletto, rather a problem with the configuration of the wireless router. Maybe call the tech support for the router also.
Dec 19, 2008 | Sirius Stiletto 2 Satellite Radio Receiver
Loss of Connectivity
Libog1 - did you install any additional wireless software to connect to the router (Linksys software) or are you just allowing Vista to connect directly using Windows' built-in wireless management?
Ben
Mar 03, 2008 | Linksys Wireless-G WRT54G Router
Can't connect to Linksys WRT54G when security is enabled
ccmfaniam:
Please make sure that the type of the security on the router should match on the computer as well. Also make sure the SSID on your router is the same in as your computer.
If this does not work, make another profile onto your computer, or simply click on the wireless icon and it should ask you for the security pass, put in the pass and you should be in.
At the moment I would strongly recommend to make another profile on your laptop, right click on the wireless icon, properties, wireless networks, make sure that the use windows to configure is checked and under prefered networks add the profile of the existing router with same SSID and security you are trying to use.
Let me know!
Dec 25, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
