Question about Mark Of The Unicorn MOTU Traveler Sound Card
My traveller is noisy on the four preamps when the phantom power is energised. I thought it was my GATT LD5 mic at first, but my ALESIS mixer powers it up no probs and no noise. So, any thoughts ?
The problem is hardware and only a skilled Technician to resolve, it is safer capacitors are damaged by weather dry out and make those noises. I have that problem too but Motu does not provide the service manual. I'm so technical and try to repair the unit without the diagram.
Posted on Jul 22, 2013
Hi Steveclar
Sorry can't help you, just wanted to say I have the same problem.
More details of my problem here :
http://homerecording.com/bbs/showthread.php?t=303759
If you get it sorted can you reply to this thread and I will be notified.
Cheers
Posted on Jun 03, 2010
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
\berenger microphone not working
Since you did NOT give us the model number of the Behringer mic, we can't do much to help... HOWEVER many of the mics are "condenser" mics that REQUIRE "Phantom" power from a mixer or preamp. These will NOT work without the phantom power being supplied. Look up your model number and see if it might be a condenser type.
May 09, 2012 | Shure SM58 Professional Microphone
I have a condenser mic, and it needed phantom power to work, so I bought the Ultra Di-100, but I don't know how to make my mic work with it.
Sorry, but the DI-100 can OPERATE on phantom power, not supply it. If you have a mixer that has phantom power then you have no need for the DI box. DI boxes are to convert unbalanced signals to balanced to send via XLR or TRS cables.
If you don't have a mixer that has built in Phantom power or a source of Phantom power, then you need a mic preamp that can supply the phantom power.
Here is an example device, but DO shop[ around as you should find some even less expensive. Make sure they have phantom power.
http://www.amazon.com/M-Audio-Audio-Budget-Microphone-Preamp/dp/B000CZ0RZG
Dec 21, 2010 | Behringer Ultra Di-100 Active Direct Box...
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
Low mic output on BEHRINGER XENYX 1832FX
You don't indicate what type of mic you are attempting to use. From your description, I would guess that you have a mic that requires phantom power. I believe that there is a phantom power switch on your mixer. Try turning that on to see if that resolves the problem. Phantom power will not harm a standard mic. Please update this with your results.
Thanks,
Dan
Apr 06, 2010 | Audio Players & Recorders
I have a 6 year old rode nt2000 large diaphragm microphone which is making fluttering noises constantly. I'm fairly certain it's not any of the potentiometers being that the noise is very consistent...
This mic likely has a built in preamp. BEFORE you open the mic, verify that your pahntom power from your preamp is clean.
If you are unfamiliar with phantom power for mics, google it to find a treatise.
Noisy or failing phantom power could be your problem. Also the preamp in the mic could have a problem rather than the diaphram. Dust would NOT normally cause what you are describing.
Sep 28, 2009 | Rode NT-2000 Professional Microphone
Need to know if we can hook a phantom powered microphone to our shs audio amplifier
Does your microphone have it's own built in phantom power? If it's just a regular mic, you should be able to connect into any MIC inputs on your Amplifier. Otherwise, you'll have to utilize a mic/line mixer to provide the phantom power your mic needs. Then you would connect your mixer to the amplifier.
Which SHS Audio amp do you have? The ones that I am familiar with do not have any MIC inputs.
- OPTiC
Master Tech
DJ PRO AUDIO
Pro Audio Equipment : Pro Audio Repairs
Aug 30, 2009 | Audio Players & Recorders
(need more tracks) dp01
I'm guessing that you're asking whether the mixer needs phantom power to the mics in which case the answer is that you wouldn't need power there if the mic preamp is providing it already. You'd just plug the mixer's main 1/4" outputs into the DP-01s 1/4" inputs. The 1/4" inputs on the DP-01 are not powered anyway, only the XLR jacks can be powered by turning the phantom power switch on.
Apr 02, 2008 | Tascam DP01 All-In-One Recording Package...
Mark Of The Unicorn MOTU Traveler Sound Card Logo
281 people viewed this question
Top Mark Of The Unicorn Computers & Internet Experts
David Payne
David Payne
Are you a Mark Of The Unicorn Computer and Internet Expert? Answer questions, earn points and help others
