Question about Haier HVUE06BSS Stainless Steel Wine Cooler
Haier HVUEB06SS wine cooler - No power? - Haier HVUE06BSS Stainless Steel Wine Cooler
SOURCE: haier wine cooler
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Posted on Mar 18, 2008
SOURCE: HAIER WINE COOLER HVW18bss I
IS THERE A THERMOSTAT YOU CAN JUMP OUT WITH A SMALL PIECE OF WIRE?IF THAT DOES NOT WORK A THINK YOU HAVE A LEAK SOMEWHERE,CHECK ALL THE PIPE CONNECTIONS TO SEE IF YOU SEE ANY OIL,LET ME KNOW-MIKE
Posted on Sep 21, 2008
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
ramon49
  • 111 Answers
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Posted on Mar 09, 2009
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Where can I get a Haier swwitching power supply
Call 800-313-8495 for Haier Parts Dept.
The upper and lower are 2 different part numbers.
Jan 31, 2010 | Haier Refrigerators
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Oct 28, 2007 | Haier BC112G Wine Cooler
Haier HVUE06BSS Stainless Steel Wine Cooler Logo
63 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
