Question about LG L1520B 15" LCD Monitor
I HAVE A LG 15" FLAT SCREEN TV. TRIED TUNING. MESSAGE SAYS NO CHANNELS FOUND CHECK ANNTENAE CONNECTION. BUT I AM POSITIVE THE CONNECTION IS GOOD.
  • LG Master
  • 12,061 Answers
To check if it is your antenna or TV, see if you can display ANY other signal, say from a VCR, a DVD, or a PC. IF it does, then either your antenna is NO good, or the Tuner in the TV has gone bad.
http://www.eserviceinfo.com/downloadsm/18389/LG_L1520B.html
service manual
Posted on May 09, 2010
Testimonial: "thank you this has sorted out the problem.best wishes dave"
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
Mar 28, 2015 | LG 26LE5300 26 in. LCD HDTV
Unlock the code for lg tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Dec 05, 2014 | LG Televison & Video
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
I was trying to hook up a DVD player via the Component 1 and I also tried the Component 2, when hooked up I got a picture and perfect sound but the screen was like watching a black and white pic. It may...
i would not recommend it other than maybe a keyboard duster, the problems your are encountering sounds like cable issue symptoms. have you tried swapping out the cable.
May 29, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I can't get all the channels from the cable
You can contact your local Cable operator regarding it since you have tried channel tuning you might aswell inform them that your not getting what is supposed to be..
May 29, 2010 | LG 37LG30 37 in. LCD HDTV
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
LG L1520B 15" LCD Monitor Logo
141 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
