Question about HP PhotoSmart C4280 Laser Printer
Scanner not Functioning
The copier and print piece work fine. But when I try to scan ; I get the USB is not plugged in and it is. I took it out and replugged it and turned the printer on and off. Nothing. How do I get it to work?
  • sparklez Apr 03, 2008
    keep getting the same message usb not found
  • angel perez Sep 08, 2008
    every else work find copy ,print,but i just can scan,say ub not connetted.
My three in one c5280 printer does all except scan and I get a message that my usb is not connected, what can I do to fix it?
Ian
Posted on Aug 09, 2008
Hey Buttercup, try this: http://www.fixya.com/support/t365181-scanner_work_but_printer
Posted on Mar 31, 2008
2 Suggested Answers
SOURCE:
  • 4 Answers
SOURCE: Scanner not Functioning
I had the same problem on my Mac.  I downloaded two things off Canon's website and all is now working:-
1) Scanner driver (ScanGear for Mac OR MP Drivers for PC) 2) MP Navigator software
Visit: http://software.canon-europe.com/products/0010249.asp  and choose your drivers.
Restart your machine (with the MP40 switched off) after downloading Switch on, and press Scan... et voila!
NOTE: after putting my Mac in slep mode, the scan button didn't function, but all I had to do was switch the MP450 off then on again for my Mac to recognise it.
Hope this helps!
J :)
Posted on Aug 16, 2008
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
USB NOT CONNECTED ERROR WHEN IT IS CONNECTED
This is a HP hardware/software error and HP has not fixed it.
The C4250 may report that "USB is not connected" but the printer works just fine and when you use the Microsoft Scanner and Camera Wizard to carry out a scan, it works just fine too. So the error message is wrong.
The Microsost Scanner and Camera Wizard can be found on the Control Panel.
May 05, 2009 | HP Photosmart C4250 Multifunction Photo...
Printer not communicating with computer
Try go to system prefs, print and fax. Remove your printer from list then add it again. It may pay to uninstall software first, then reinstall
Apr 29, 2009 | HP Photosmart 3210 Printer
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
C4200 - says USB not connected when trying to scan
Mar 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Canon pixma MX310 scanner not working
I read somewhere that the printer/scanner must be plugged directly into the computer in order to scan.  I tried it, and it works.  Printing can be done wirelessly, but apparently not scanning!
Oct 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Scan problems with Canon MX310
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Hope this helps!
J :)
Jun 24, 2008 | Canon Pixma MP450 All-In-One InkJet...
HP PhotoSmart C4280 Laser Printer Logo
200 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
