Question about Pioneer AVIC-Z110BT GPS Receiver
All my settings are gray accept my av sound and it
When I go to settings screen I cannot access anything except av sound which my subs are homed to. All other settings are grey I can't even change the time. I can't access the nav settings blue tooth nothing
How do I fix an LG TV that shows a gray screen for the first 10-20 minuets when it is turned on?
First, try to plug another source on your T.V. set and let see if it's gonna do the same trouble. If not, this is not the T.V. but the source,( cable box or other) that is defect. If not, Looks like a main board problem, or if you're lucky, a cold joint, (Which i doubt). Sometimes it could also be a bad piece in the power supply but i can not say like that. I would have to make test on it with the service manual. If changing source does not work, i suggest you to see a professionnel. Best of luck. Best regards,
Serge.
Apr 07, 2015 | LG 32LG30 32 in. LCD HDTV
Have a Dell inspiron 1525 laptop originally I could not control anything on it because I bought it 2nd hand and did not have admin password
If it won't accept the hdd password you set, you must purchase a new hdd and install windows and drivers and all of your programs before restoring your data from a backup.
Feb 06, 2014 | Dell Inspiron 1525 Laptop
Subwoofer not working in my av reciever str-dk5
Are these line level in subs? If they are, it's unlikely two are bad. Please check you audio settings in the receiver menu.
Feb 03, 2014 | Sony DAV-DX255 System
How to set a RX-V440 in order to be able
Check the settings. refer to its user manual.
Jun 03, 2012 | Yamaha Audio Players & Recorders
I have a Yamaha RX-V992 receiver and I would like to install a Bose 901 active equalizer Where will I connect this to my receiver? Thanks, Mark
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Assuming you want the 901's as part of your multichannel sound, you need to get a dedciated power amp just for the 901's and you don't need to use a Tape Monitor loop.
You can draw the Front Left and Right signals out of the Main Out connectors, go into the Active EQ's Amplifier IN Connections; then Out of the EQ's Amplifier OUT Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Run through the speaker level settings with the new amp at a suitable volume setting (if it has a volume knob; many don't). Then leavethe amp volume control alone.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed and control the volume on everything.
This is roughly how I do it.
Mar 17, 2010 | Audio Players & Recorders
Im in Australia I have a haier HTR-039 tv. It went into some settings mode (not the menu settings) and wouldnt go back to normal After messing around with some settings I got it to go away im not sure what...
HELLO
It appears you have accessed the SERVICE MODE settings - they must not be messed around with under any circumstances except for a service technician.
Contact a service centre who may just be able to put things right. Do yourself a favour - don't access this menu again! (:-)
Sep 30, 2009 | Televison & Video
Playstation wont connect with av cable
is it just the tv screen saying no signal? if so you may still have your tv in HDMI mode if not then you need to go into the television settings
Dec 03, 2008 | Sony Playstation 3 (PS3) Console
Rca rtd2006 usb slot
The usb slot does not except anything too complicated.. So pretty much it accepts simple mp3 players, and flashdrives.. anything else will just result in the message you got.
Jun 12, 2007 | RCA RTD207 System
Pioneer AVIC-Z110BT GPS Receiver Logo
64 people viewed this question
Top Pioneer GPS Experts
Michael Galve
Michael Galve
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
