Question about Electrolux 24 in. ESI6220X Free-standing Dishwasher
Not cleaning pots 100%
When i open dishwasher no steam as tho water not been hot also the washing tablet does not always dissolve fully hence pots not properly clean many thanbks for your help
  • 269 Answers
Does it still seem to be doing a normal wash except that you have no heat when wash is on.This could be a faulty Heater or Programmer.
Hope this was a help.
Good Luck.
Posted on May 09, 2010
Why is it not cleaning dishes?
Contact one of the Asko authorised repairers in your area and they will be able to tell you the likely cause provided the water in your machine is heating up to the correct temperature and not trying to wash luke warm and without the powder dissolving properly.
Set the machine for a hot wash and stop it and open the door mid wash cycle and check how hot the water is. It should be extremely hot and you should get a mass of steam rushing out when you open the door.
Jan 10, 2016 | Asko 24 in. D3121XL Free-standing...
Detergent tablet will not dissolve?
Check water temp in might be to cool that is the first step......
Oct 06, 2014 | CDA WC430 Dishwasher
Detergent tablet not dissolving.
sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
if this is helpful please click the correct button. thanks
Jan 22, 2010 | Zanussi Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Not washing properly.fills and water circulates but does not always dissolve all of tablet and does not clean both top and bottom shelves. checked arms clear. What next?
There is not enough salt in the dishwasher & that is what causes the sand like residue on dishes. Sometimes even when you use an all in 1 dishwasher tablet this may still not contain enough salt for the hardness of the water in your area. Using salt regular helps keep the dishwasher clean. The problem is hard water going into your dishwasher. it leaves the residue you are talking about. There is a new affordable product called the dishwasher filtration system it filters out the hard minerals that cause this before they enter your dishwasher leaving your dishes spot free with every load. You can get it at www.dishwasherfilter.com.
Thanks for contacting fixya.com
Nov 24, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Tablet not fully dissolving. dishes not clean after wash.
The water is not hot enough. It may be pausing to heat the water and when you open the door it resets and starts again. Check the electric element at the bottom that heats the water to see if it is burnt out.
Jul 22, 2009 | Dishwashers
Dishwasher tablet doesn't dissolve
Need more information. What kind of tablet? What kind of dishwasher?
Jul 19, 2008 | Dishwashers
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwasher tablets not dissolving
It may just be the way you are loading the machine.  If the dishes are not allowing the the detergent door to open fully, the tablet sits in the dispenser until you open the dishwasher, letting the dispenser door open and the half dissolved tablet falls out!     Try being more careful how you load the machine or just chuck the tablet in the bottom of the machine instead of the dispenser!
Apr 10, 2006 | Bosch 24 in. SGS66E02 Exxcel Built-in...
Electrolux 24 in. ESI6220X Free-standing Dishwasher Logo
95 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
