Question about DISH Network IR Remote Control
Time delay between pressing remote and reaction on screen
Time delay between pressing and reaction
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 358 Answers
Stevec795
Do you have fresh batteries in the remote? Drained batteries can cause the delay problem. If you do have fresh batteries, then you will need to readdress the remote to the receiver. I have provided instructions on readdressing the remote. I hope this helps.
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Posted on Feb 02, 2011
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and...
every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Oct 14, 2013 | Heating & Cooling
The phone only rings four times then it goes into answere
Here's how to set the ring delay:
Setting the Ring Delay
The Ring Delay setting determines the number of times the machine
rings before it answers.
1 Press Menu, 2, 1. .
2 Press Z or X to select RING DELAY.
3 Press Set.
4 Press Z or X to select how many times the line rings before the
machine answers.
5 Press Set when the screen displays your selection.
6 Press Stop to exit.
Mar 05, 2011 | Brother FAX 930 All-In-One Thermal Printer
What settings do I use on d5000 to work with a remote control please help
Press the button to bring up the information display screen. Press the button to put the cursor into the information display screen. Use the cursor keys to select the release mode (fifth item from the top, along the right edge of the screen) and press OK. Select one of the two remote modes. The quick-response remote mode fires the shutter when you press the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back.
Full details are in the "Release Mode" section of the manual (pages 65-69 in my copy).
Feb 10, 2011 | Nikon D5000 Digital Camera
Car shifts hard (up & down), especially shifting to reverse.
that delayed reaction may be the transmission slipping. with those many miles it could be the transmission going bad
Feb 21, 2010 | 1992 Honda Accord
2004 chevy trailblazer seems like the steering is loose. what might cause that?
Do you mean the steering wheel seems loose or the truck itself is loose, meaning you turn it and the reaction seems "delayed".
If the wheel itself is loose there are bearings inthe shaft that wear (pretty common) or you may have a front end compnent wearing out if the reaction is delayed.
Jason
Jul 13, 2009 | 2004 Chevrolet TrailBlazer
FREEZY AND DELAY REACTION
If you are overclocking the unit...there is your answer, it is NOT recommended by any cpu manufacturer in fact they try to discourage the practice because it makes the system unstable and prone to lock-ups
Apr 25, 2009 | Intel Motherboard
Mouse is glitchy
I would recomend a RAM upgrade, That speeds up the reaction time of your computer
Jan 11, 2009 | Dell Inspiron E1705 Notebook
Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Dec 10, 2008 | Logitech Harmony 880 LCD Remote Control
Blinking screen???
My phone has been doing the same lately. Sometimes it will often come on then turn off again. Often it will freeze up or have a delayed reaction. My suggestion would be to go to a vz Store.
Jan 23, 2008 | Samsung SCH-u740 Cellular Phone
DISH Network IR Remote Control Logo
402 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
