Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon Pixma MP500 Reset PAGE SIZE to A4
Canon Pixma MP500
How do you reset PAGE SIZE to A4 as default setting
How do you reset MEDIA TYPE to Plain Paper as default setting
  • Anonymous Mar 12, 2014
    reset settings for canon pixma
    Brigadier General:
  • 4,090 Answers
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
Posted on May 09, 2010
    New Friend:
Solution (that worked for me)
I uninstalled the printer completely and deleted all drivers. Then re-installed, and all is working normally.
Posted on Jan 27, 2014
How can i set printer setting to default to: 8.5x11 plain paper standard so that when i turn the printer on it is on that settinf?
I could not find a way to do this either Anthony. What i ended up doing was selecting the bottom tray to print from the pc - it seemed to hold the setting for A4 plain paper, whereas the default setting stays at 6x4. A real fault with this otherwise quite cool little printer.
Although, I am having real probs at the moment, the damn thing just wont switch on after we had a power failure in our part of town.
In fact, the entire switch mechanism seems a bit "dicky" all up.
Good luck, hope you find your answer.
Feb 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Scanner image is askew
Base on your explainination it seems like, this is because of your setting in MP Navigator, the image may not be scanned properly. In such a case, it is necessary to match the settings in MP Navigator to the document. please do the following. 1) Match the type of the document on the platen glass to the document type set in MP Navigator. For example, when scanning a color photo, select Color Photo in Document Type of MP Navigator. 2) Match the size of the document on the platen glass to the document size in MP Navigator. For example, when the document size is A4, select A4 in Document Size of MP Navigator. (Memo) Auto Detect is set in Document Size as the default.
Sep 09, 2007 | Canon Pixma MP500 All-In-One InkJet...
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print page settings revert to 6x4 when using as a photocopier, rather than A4
1-In copy mode, display the Settings screen by pressing "Settings" on the MP500.
2-Select the Setting Tab using the left and right arrows.
3-Select the page size by using the up and down arrow.
4-Select "A4" by using the left and right arrows.
5-Complete the setting by pressing Settings
Aug 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have an imac. When I try to print on my mp500, after carefully checking all the page setup settings (8.5x11, center, rgb), I get a monotone of my photoshop pdf file; and it also reduced the size of file...
Go into your printer properties located in the control features of your operating system. You can change the default properties within that and it will default to color, quality and size for each of your program applications without having to change it each time.
Feb 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Only prints 25% of page
are you sure it's set to Letter? and not A4 or a diferent size?
Aug 12, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
No Paper Recognised
What paper type is set in the driver? ie plain, letter, A4, cardstock?? Also which tray source is accepted. Might try re-setting driver settings to defualt.
Aug 29, 2007 | Canon Pixma MP500 All-In-One InkJet...
Default settings for copier
There must be s "custom setting" set as default. Check properties and restore defaults where applicable. http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 This is an online manual for your machine. Good Luck, Tim
Feb 06, 2007 | Canon Pixma MP500 All-In-One InkJet...
Printing
I wonder if it is in fact a printer problem? have you tried different programs?
Aug 18, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
602 people viewed this question
old marine
old marine
