Question about Canon PIXMA MP130 All-In-One InkJet Printer
Printer cartridge jammed
When I try and print there is an eroor saying the cartridge is jammed
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 09, 2010
The printer says that there is a cartridge jam and it will not print.
Does it say "cartridge jam" or "jam in cartridge area"?
If it is the latter open the door and remove the jam.
Then press the SELECT button to continue.
Feb 26, 2011 | HP Color LaserJet 2600n Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
It starts printing, then stops, the printer cartrige is jammed
Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
Will not print
i think some **** of paper might be stuck inside the printer mechanism, carefully check it. if no, try the following :
* unload the cartridges and reload it back
* keep the printer offline (disconnect from the pc) and try copying something
* realign the cartridges with a former printed alignment sheet (i think u may have known how to align it)
May 15, 2009 | HP PSC 1315xi All-in-One Printer
Paper jam
are you sure you have put the cartridge in correctly, remove cartridge and put again carefully.
Mar 27, 2009 | HP LaserJet 1020 Printer
Cartridge Jammed
Try removing the print cartridge and then insert it again this should clear the problem.
Feb 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Canon PIXMA MP130 All-In-One InkJet Printer Logo
198 people viewed this question
old marine
old marine
