Question about Sherwood VR-652 Theater System
DISC ERROR OCCURING TIME AND AGAIN
Dear team,
Kindly help me for the same, as and when we insert the DVD or CD into the system, disk error occurs and the system is unable to read the disc.
Rest FM and other parts are working properly.
Would be looking forward for your perusal action.
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropylic alchool to clean up the cd lens manually. In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 13, 2010
I turn it on with the disk in the gamecube and it goes to the cube screen. Then i look at the disk part of it and it says that there is no disk but there actually is a disk.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Nov 06, 2010 | Nintendo GameCube Console
The cd/dvd writer constantly open and close once a disc is inserted. On insertion of a disc, cd/dvd player will read the data on the disc. Windows Media player will display realtime image of the movie,...
Hi Charles,
The issue is due to the driver corruption. You need not worry, there is a simple solution for this.
Go to device manage --> right click on your CD/DVD drive and then click uninstall and then restart your computer. Do not keep any CDs while you do this. Just try this out.
Oct 25, 2010 | Dell Dimension E520 PC Desktop
Won't read discs. Says no disc numerous times of opening and closing, then occassionally it will read the disc.
If this problem occurs only at this cd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Stelios
Sep 17, 2010 | Philips HTS-3555 System
In my system the dvd disc is still ssometime
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set.
The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Stelios
May 12, 2010 | JVC Audio Players & Recorders
Dvd sometimes reads error
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
Thanks and regards
Stelios
May 11, 2010 | Samsung HT-Q20 Theater System
When i insert a dvd into the player it is not reading the dvd and no disc is coming up on display screen
If this problem occurs only at this dvd it's a disk problem. If it occurs on various disks try using a dvd cleaner set, a wet one for better results. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
Thanks and regards
Stelios
May 09, 2010 | Philips HTS6510/05 Theater System
Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
Thanks and regards
Stelios
May 08, 2010 | Panasonic SC-DK10 System
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My cd rom/dvd drive will not read any disc
Check the cd-rom power is on or not. Then also if its not reading then Insert an DVD/CD cleaner disk and follow the steps. The cleaner disk is available in any of the computer shops. There may be some lens problem. After trying above steps if again same problem occurs then you need to replace the cd/dvd rom drive. Thank you.........
Sep 14, 2008 | Sonic Computers & Internet
DVD will not finalize
Bad Disk batch is the most common problem if it is occuring with the same batch of dvds. Other problems could include that you need to get a firmware upgrade for higher speed discs. If you are using a disc that burns faster than the current speed of the machine you need to download the upgrade (follow the directions that are given in most dvd blank packs) and insert the CD that you downlaoded the program onto into the DVD player/recorder.
Feb 09, 2008 | Zenith XBR716
Sherwood VR-652 Theater System Logo
127 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
