Question about Dishwashers
Brand new beko DE 2542 PW dishwasher won't start wash cycle
Brand new beko DE 2542 PW dishwasher, filled up with rinse aid & salt but even though the wash light is on it only makes a noise for a little while and then doesn't actually do anything.
Makes the same noise every couple of minutes or so but still does nothing.
  • 269 Answers
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
Posted on May 09, 2010
  • johigginson
    johigginson Jan 24, 2012
    Thanks sooooooo much this is the second Beko we have installed nowhere does it say in the instructions there maybe a black plug, several calls to Beko and a replacement dishwasher with what appears to be the same issue and 30 mins on here and you have sorted it! thanks again a very happy camper am I =)
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
My beko dishwasher is not rinsing properly, we add rinse aid and salt and the pots still come out with **** on then and are not being cleaned properly even on the hottest wash
Try running a dishwasher cleaner through it, it will break down any built up residue in the machine, with using salt to soften the water it can build up in places and reduce water flow.
Mar 06, 2012 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Cloudy looking dishes?
Check water quality. If more of calcium or hardness is present, this situation could occur. As per manufacturers directions fill salt meant for dish washers, in the dispenser provide in the door( Inside). This will improve the quality of the water.
Fill rinse aid liquid as per the directions. Refer user manual.
May 25, 2010 | Kenmore 15922 Built-in Dishwasher
Film on dishes and inside stainless steel panel
You live in a hard water area. Even though dishwasher tablets have salt included you may have to fill the machine with extra salt. (its the large srew top cap in the bottom of your machine, open it and fill it with dishwaher salt your machine came with a large funnel to help you do this) you will have to remove the bottom drawer to do this. next make sure you have rinse aid installed in the door of your machine, next to where you put the tablets in (don't buy cheap rinse aid it's not worth it) when its full of rinse aid the indicator will turn dark, will need both salt and rince aid about every 30 cycles.
Nov 05, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Aug 31, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
1,030 people viewed this question
Top Dishwashers Experts
