Question about Compaq MS Windows XP Home Edition for PC
Hi i have a on screen message saying connect cable
  • 74 Answers
Display Code not attached with your PC please attached it.
Posted on May 11, 2010
Hi there - Why do I keep on getting a message saying 'Playback error has occurred, please try to reload the page'. I did a few speed tests and my connection is between 4.5 and 5Mbps.
Hi, how are the Apple TV and MacBook Pro connected to the network, could be a flakey WiFi connection and/or lots of traffic on your local network... are you able to connect both via ethernet cable and retest, how many other users connected to your network? Cheers, John
Aug 27, 2017 | Apple Computers & Internet
My dynex lcd tv keeps saying no signal when cable is plugged in?
It sounds like the CATV portion of the TV tuner is bad--Cable band.
You may have an option---with a cable box that has the audio/video jacks for output of signal on its rear side connect to a unused video input on rear of set--go to that input and change channel via the box---BY PASS THE TUNER IN THE SET THIS WAY.
May 25, 2012 | Dynex Televison & Video
I have connected the cable from the printer to the lap top correctly but it still comes back saying the the laptop cannot recognise the printer. The connection was bought from Currays and I was assured it...
Hi graham_mcleo
The printer came with a install disc ( cdrom ) .
Disconnect the printer , launch the cdrom , follow instructions and wait for the driver/software to be correctly installed . Connect the printer with usb and power cables , swich printer on . Windows should recognize a new hardware and a message should pop on your screen telling installation was successfull or hardware is ready to use , depending on what system you are using .
Aug 11, 2011 | Computers & Internet
Monitor shows on no picture
The first thing that we will have to check is if it is a hardware problem or not so to check this we need to do a self test on the monitor.Disconenct all the external devices even the cable for the internet so the cables that should be connected would be the cable for the monitor,power,keyboard and the mouse.Disconenct the cable for the monitor that is the VGA cable that has a blue connector whic has screw's on it .Once that is disconnected turn the computer on ,you should be getting a message on the monitor that has a message no input signal or check video cable .There has to be some kind of message that tells you that the cable is disconencted .If it has a message then it means the monitor is good or else if no message then it tells us that the monitor has gone bad and it needs to be replaced.
If the monitor has the message then turn the computer off and then when u turn it on tapp the F10 key for XP and F11 for vista ,tapp the key until you get a black screen that says advance boot menu options then select the option that says enable vga mode and then hit the enter key .When you get the log on screen select administrator and then it will take you to the desktop .Please tell me what happens so that i can help u further .The trobleshooting steps vary depending what is the response by the computer so i am waiting for your reply...
all the best
May 09, 2010 | HP W22 LCD Monitor
I have s samsung monitor T220 and will not come to show that my computer is connected, I have a message on the screen that says check signal cable with the word digital at the bottom of the message box....
oh i had the same issue with T220, remove all ur memories , disconnect the monitor , remove the graphic card, clean it and instert it back , insert the memories and then connect the monitor to analog cabl;e first,,, put it on and then shut it down and then move back to digital sorce with the cable changed
Jan 11, 2010 | Computers & Internet
I have a new lgkc910 phone. I've installed pc suite on my pc and followed all the instructions. It says it's connected but whenever I try to actually do something it give this message: Fail to connect to...
You didn't say whether you are trying to connect remotely or with a cable. I would suggest getting a cable from ebay. should only cost you a few dollars. As soon as you plug in your phone to the cable which is connected to your PC it should give you the message "connected to lgkc910" or something similar.If you have 2 USB slots try the other one. you may have a probelm with that slot.
Oct 26, 2009 | LG KC910 Renoir Cell Phone
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Mp3 froze
Just leave it until the battery runs out. thats what i did when mine did the same thing and it started working again
Dec 18, 2007 | Samsung Yepp YP-T9 Digital Media Player
Olevia LT23HVX screen resolution
what kind of cable are you connecting with? If you are using a Composite or S-Video cable perhaps you may want to use the VGA cable instead and see if that corrects the issue.
Nov 29, 2007 | Olevia LT23HVX 23 in. LCD Television
Compaq MS Windows XP Home Edition for PC Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
