Question about HP Pavilion DV6500T Notebook
Dvd rom not working
My dvd rom is not working. my system cannot detect it. when i click "My Computer" DVD rom is not there.
  • HP Master
  • 1,606 Answers
That usually means the drive has failed and needs to be replaced. You may have noticed that it was slower and noisier shortly before it stopped. It probably stopped be able to burn dvds, then cd first, then it had problems reading dvds but would read cd's then finally nothing. Thats the typical pattern. Some just go from normal to nothing but thats not as common.
The cd/dvd drive is a simple repair and easily attempted. There is one screw that holds the drive in place on thebottom. Undo that screw and the drive slides out. Push the new drive in and put the screw in and you are done.
You can buy a replacement drive from several places including HP. You want to get it from a third party not HP. HP charges more. You should check to see if you have any warrenty either from HP or the store. they will replace this under warrenty. A replacement drive for this looks to be rather expensive at $200+ even from third party suppliers. Those can be found simply by searching for 'laptop replacement parts' using google or bing. Then looking up your specific model.
Posted on May 09, 2010
That happened 3 times on my computer when it was still brand new! They replaced the drive, and it happened again. It is a registry problem that Itunes causes. Every time I download Itunes, I lose my DVD drive. I have read on the internet that this is an Apple problem that they will not address, but apparently it is not happening all that much with Windows 7, mostly Vista. i was able to get the Drive to be recognized through a few steps that were not all that hard. Listed on google problem solvers
Posted on May 26, 2010
Hi, i am using LG dvd rom HL-DT-ST_DVD-RAM_GSA-H55N on Windows XP platform. my dvd writer is detecting cd's but not detecting dvd's.i had flashed the dvd rom by LG firmware but that does not...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard
hope this helps you
Sep 10, 2011 | LG GSA-H55N DVD-RAM Burner
MY dvd writer not detect dvd. but detect cd. this is dvd problem.
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope it helps
Aug 30, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Dvd not reading
The objective here is for us to determine if the dvd is bad or Operating system is causing DVD not able to detect DVD's or cds
Hardware Issue
1. Try booting the computer from the DVD. Use the windows XP or vista or windows 7 to boot with it
2. If the DVD boots up. Definitely the DVD rom is working because it can read dvds outside of windows proceed to step 4
3. If it does not boot up make sure that the dvd is working on another DVD rom. And we are sure that the dvdrom is bad and needs to be replaced
Software Issue
4. Click start -> Click Run (Windows XP)/ Start Search (Vista) / Search Programs and Files (Windows 7)
5. Type Regedit
6. Click on the triangle/plus sign beside HKEY_LOCAL_ MACHINE
7. Click on the triangle/plus sign beside SYSTEM
8.Click on the triangle/plus sign beside CurrentControlSet
9.Click on the triangle/plus sign beside Class
10.Click on the Folder {4D36E965-.......}
Note: The first 4 digits might be the same we need the digit that has a 65
11. Restart the computer and your done
Jul 07, 2011 | Computers & Internet
Ffdh
Could you please explain the problem a little bit. Are you not able to detect the DVD inserted or the icon for "DVD Rom" in " My computer" is not responding?
If you are not able to detect the DVD ROM in the "My Computer" then To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start , type regedit in the Start Search box, and then click regedit in thePrograms list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, if you have UpperFilters, right-click UpperFilters, and then clickDelete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, if you have LowerFilters, right-click LowerFilters, and then clickDelete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
It should be able to detect the drives now.
Cheers.!!!
May 15, 2011 | Dell 16x Beige Internal DVD ROM - NEC...
My dvd drive is not reading any disk but it is detecting
Click start go to all program, accessories right click on Run then type in the blank field regedit then follow theses folders : Click these folders -HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control\Class
{4D36E965-E325-11CE-BFC1-08002BE10318} > this will show the DVD/CD-rom then look fo upper filters and lower filters right click on both one at a time I mean if you have it on the screen then left click on delete after deleting both or any one of the two restart the computer then try your DVD-rom if it will be detected and if it will read any discs
Jun 17, 2010 | LG GSA-H55N DVD-RAM Burner
Dvd rom drive does not work
Try to open control panel then click add hardware. If you have entered the dialogue box, answer whatever is asked according to what you're searching. Then click whatever hardware your PC would like to detect then click finshed. After the detection, close the wizard box then try to open your DVD ROM and try it.
Hope this answers your question.
Feb 18, 2010 | Artec 16X DVD-ROM 48X CD-ROM Drive with...
Display Dvd Rom
Hello my friend, please try to reboot your computer then goto CMOS and check if the DVD Rom that you have is detected by your system. If it does not detect then you can manually detect a device using CMOS function. Also try to check if the connectivity of your DVD Rom is not diabled otherwise enable it to detect your device. If all the above steps you followed then the result is still the same then please find a computer technician in your place then let him open and fix the problem.
If you need more assistance my friend please reply to this post.
Thank you.
Jul 28, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
My cd/dvd does not show up in my computer
Check your system BIOS whether it is Detected there, if no, Shutdown your system, Press your CD-Rom drive towards the system firmly (Incase its making a partial contact), and restart your system. If Yes, then Start your system, Right-Click on my computer, go to properties, Device Manager, DVD/CDRom Drives. and click on it. if your CD Rom Drive is not detected there, then on the Device Manager Screen, click on Action, Scan for hardware changes, your system should detect it automatically. But if its already there, right-click on it, Uninstall it and do the scan system for hardware changes again. It should solve the problem like that.
Jul 09, 2009 | HP Pavilion zd8000 Notebook
I have a Compaq PC and yesterday it stopped recogzning my DVD rom drive. What could be the problem?
There would be serveral reasons for not recognizing the dvd..
-> May be the Problem with the wire not connected properly in the tower
->May be the Problem with Operating System.
-> May be the Problem in the registry with upper/lower filters.
Solutions :
-> Check with the wire properly connected or not opening the cabinet.
check whether the dvd rom detected in bios.
if detected check with rocognizing the dvd rom drive in Operating system.
-> Try Reinstalling the operating system(if detected in bios & not recognised in Operating system).
-> Try editing registry by clicking on Start -> Run ->type regedit and push enter.
->Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete Upper filter and Lower filter , and reboot the computer. The optical drive shows up under My Computer.
May 02, 2009 | HP Compaq Presario SR2011WM PC Desktop
MY DVD DRIVE DOES NOT WORK THE COMPUTER SAYS NO SUPPORT DRIVE CAN YOU HELP
we may need more details
1. did it ever work or you just installed it?
2. where do you get the no support drive message? after clicking what?? after doing what? in what program?
3. find out if your computer actually sees the dvd rom drive being detected.. go into start>righ click my computer>properties>hardware tab>device manager and look into cd/dvd rom drives ... do you see your dvd rom drive there?
Sep 21, 2008 | Computers & Internet
HP Pavilion DV6500T Notebook Logo
121 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
