I have a Bose Lifestyle 20 system (approx 15 years old) I have successfully linked the system up with the sub-woofer and two twin speakers for Zone 1. I did have a Bose Acoustimass 5 Series III speaker system hooked up through a Bose amp for Zone 2 - until my husband busily did something and now I can't get it to work. I did extend the speaker and subwoofer cords to connect into the amp in a different room, and I have rechecked to make sure they are correctly connected. We had the amp fixed at the beginning of the year, but that seems to be what is letting us down. If the cords weren't linked properly, could I have a) blown the amp or b) blown a speaker, which is why Zone 2 doesn't give sound, but shows power connected?
  • catherine925 May 09, 2010
    Hi Stelios
    I am not sure what the amp is - whether it is an SA-2 or SA-3. The instruction booklet doesn't differentiate, and looking on the Bose website doesn't help - as they look the same. It is a dual voltage amp and it is probably 15 years old - same as the system.
    When you talk about a headphones jack/input for an MP3 player - I am assuming you mean on the amp itself, rather than the Lifestyle 20 system box?
    Catherine
    President:
  • 1,851 Answers
One of the following reasons is responsible for your problem:
  • the speakers cables have problem (open or cross circuit)
  • the amplifier has blown out
  • the line audio cables from one system to the other have problem (open or cross circuit)
Use on small AA size 1.5V battery (not the 9Volt one, could destroy the speaker) to check the speakers and their cables: Disconnect the speakers cables from the amplifier end. Connect each speaker cable direct at the AA battery and try to hear some momentary sound from the speaker. Try for the next one. If no sound comes out, either the cable or the speaker has problem.
If the amplifier for zone 2 has a headphones output try this output to check if the amplifier is working properly. If it doesn't work, either the audio input cables are faulty or the amplifier is blown out (sometimes the fuses are not quick enough to burn out prior the amplifier). Try connecting some portable device (mp3 player or so) at line input of the amplifier just to check the amplifier.
You can try also connecting the mp3 player at the far ends of the line audio cables, as last change.
You don't clarify the amplifier's model so I can't be more accurate.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 09, 2010
  • Stelios
    Stelios May 09, 2010
    Catherine, correct I mean at the amp, but since your amp is sa2 or sa3 I think that these amplifiers have not a headphones out, so check the rest.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
My bose system does not respond to the remote. It is a patio system. Inside works fine but I cannot turn the outside off or correct the volume. I just got a new remote- same problem
Maybe, just Maybe you could try turning the power off for the sub woofer, the zone next and then the Bose itself. Power up the woofer and zone before the Bose and it may pick it up, works when the Apple TV drops out
Jul 10, 2014 | Bose Lifestyle 48 System
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Bose Lifestyle 5 speakers(woofer + 5 double cubes)
I repaired the contol unit per instructions from a post at FixYa.
Sep 11, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
Bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Jun 24, 2008 | Bose Acoustimass 15 System
BOSE Lifestyle 48 Calibration Issue
try unpluging everything apart from the headset in the aux input (make sure you plug in to the white and red NOT BLACK) Sub woofer and power cord. Also make sure the power is on the the sub woofer. rx7pat
Apr 06, 2008 | Bose Lifestyle 48 System
43 people viewed this question
 Grubhead
Grubhead
