Question about Sharp Office Equipment & Supplies
Sharp ar-5320n paper exit roller not move - Sharp Office Equipment & Supplies
  • 328 Answers
Maybe heat roller gear has broken.
Posted on May 30, 2010
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Sharp AR 207 paper gets lifted out of tray but will not continue to feed into machine. Side feed works fine
try cleaning the paper feed rollers in (above) the tray. and the rollers on the right side (theres 3 gray rollers) If thats works you will need to replace the rollers soon.
Aug 28, 2010 | Sharp AR-207 Copier
H5-01 Error, I need to clear this. How do I enter tech mode, I know the sequence is P# - * - C - * - 14 - start - execute. Its a sharp AR C 260
Did you open the left door and clean all the paper out of your fuser and exit area? If you cleared paper and code and get it again either your fuser needs a rebuild or your transfer belt if not moving paper through fast enough. H5-01 means five consecutive attemps to send paper through the fuser have failed.
Aug 03, 2010 | Sharp AR-C260M All-In-One Printer
H5-01 error
Make sure that there isn't any paper jammed behind the left door in the (hot) fuser rollers. press keys P, *, C, * enter simulation number 14 press key as if making copy. on LCD execute and clear all to exit. if code returns call a sharp technician.
Nov 12, 2009 | Sharp AR-M355N Copier
My copier keeps tearing papers.
Paper tears due to the following;
a. Improper paper size on tray
b. Putting excess papers on tray
c. Dirty feed rollers
d. improper jam removal
Rectify the above.
Nov 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code h5-01
Hello sir; the paper exit sensor get stock, just put back in the track let it moved free.
Apr 14, 2009 | Sharp AR-M350U Copier
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Sharp-275 Not a simple paper jam
This sounds like you may have a bad jam detect sensor, there is a sensor on the exit end of the fuser on the right and the flag for this is located in the middle of the exit guide on the fuser this gives us most of those types of jams.
Hope that helps...
Jun 16, 2008 | Sharp AR-275 Copier
54 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
