Question about Nokia N73 Cellular Phone
Java software installation problem in nokia n73
When i try to install any Java software on my n73, it shows only processing, and software doesn't get installed, this problem is occurring since i have formatted my memory card
    Guru:
  • 274 Answers
Ok
just remove ur memmory
then format the card by using pc
then reinsert the memory card
again format it by using file manager
DONE
Now u can install any software
Posted on May 09, 2010
Cant install #.jad file even after formatting my nokia n73
About this result
JAD (file format) - Wikipedia
https://en.wikipedia.org/wiki/JAD_(file_format)
  1. Cached
  2. Similar
Java Application Descriptor (JAD) files describe the MIDlets (Java ME applications) that are distributed as JAR files. JAD files are commonly used to package Java applications or games that can be downloaded to mobile phones.
JAD File - What is it and how do I open it? - File.org
file.org > File Help Guides
  1. Cached
  2. Similar
Did your computer fail to open a JAD file? We explain what JAD files are and recommend software that we know can open or convert your JAD files.
What is JAD? What Opens a JAD? File Format List from WhatIs.com
whatis.techtarget.com/fileformat/JAD-Java-Application-Descriptor-file
  1. Cached
  2. Similar
JAD files describe the contents of a MIDlet, a type of Java application commonly used for games and applications for Java ME (Java Micro Edition formerly known as J2ME) for mobile platforms and embedded systems. JAD files are used to identify retrieve and install MIDlets.
and finally, how to fix
Cant install jad file even after formatting my nokia n73 Google Search
Dec 01, 2016 | Nokia Cell Phones
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    I am trying to install an Java 6 update 20
    If you are using any form of Anti Virus software, it could be stopping the installation process. Go to the SUN Java website, and download the latest version. Save it to your desktop. Take a moment to reboot your machine completely. DO NOT start any other programs after rebooting. Stop or disable your ANTI VIRUS software. Install the JAVA update and reboot. The update should work, and upon rebooting after the install, your AV software should start again. If it is still disabled, enable it.
    May 03, 2010 | Sun Java Programming Language (cdj-275)
    Java installation problem
    How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
    Error: 25099 during Java installation This article applies to:
    • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
    • Browser(s): All Browsers
    • Java version(s): 6.0 , 6u10+
    SYMPTOMS
    While Java installation is in progress, a message box with the following error is displayed:
    Error 25099. Unzipping core files failed.
    CAUSE
    The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
    WORKAROUND
    Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
    Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
    Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
    Step 4 : Download and install Java.
    1. Go to Java.com
    2. Click on the Free Java Download button, and start the installation process.
    Nov 08, 2009 | Computers & Internet
    Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
    WORKAROUND
    1. Go to Java.com
    Sep 17, 2009 | Microsoft Windows XP Professional With...
    Sis intallation problem in N73
    hi,
    dear there is way to install a sis file in NOKIA N73
    coz its N-series mobile higher.
    you have only install sisx,jad,and jar files
    if you want to get some files tel me i will tel you links were you can ezzzely
    Dec 15, 2008 | Nokia N73 Cellular Phone
    Installing line comes up after each restart.
    did you tried to format your memory card via phone? if not, try it go to tools then select memory card, click option them select format memory card, then try to install some java applicatins. good lack
    Jul 20, 2008 | Nokia N73 Cellular Phone
    Install java games
    press menu option then go in application there will be installed games.
    Jun 07, 2008 | Nokia N73 Cellular Phone
    Cannot install/uninstall Java
    hi,
    It is not necessary to install java in order to use java.
    Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
    Example, if you have the java file in your C drive, do the following steps
    1. Goto start->Run-> type command. Command prompt(black screen) will open.
    2. if it shows as C:> follow the steps, else Goto step 6.
    3. set path="c:\Java file name"
    4. type javac
    5.after typing if u find compiler then Java is installed in your system.
    6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
    7. cd..
    8. cd..
    9. cd C
    10 .then it appears as C:>, follow from the step 3.
    thank you.
    May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
    Nokia N73 Cellular Phone Logo
    181 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
