How much sata hdd can d101ggc motherboard support??
  • 416 Answers
This Motherboard has 4 SATA ports. you can upto 4 SATA HDDs.
Posted on May 09, 2010
Sata hdd very slow
hard drive maybe slow 5400rpm not 7200 rpm check drive speed on them
Nov 08, 2013 | Intel D101GGC Motherboard
How much HDD (GB) does Intel D101ggc support ? I have upgraded my HDD from 80GB PATA to 500GB SATA(with out any jumper). MB- Intel d101ggc, P4 Processor. RAM 1GB, But after that my PC got slow. It takes...
You then must have re-installed your XP, and if no other Hardware configuration changed then it sounds as if you do not have all the necessary drivers reloaded.
Check your Device manager if there are any notifications and update all drivers.
Then look at this and follow these steps to also identify where your issues may be.:
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/sag_mpmonperf_15.mspx?mfr=true
Sep 12, 2012 | Intel D101GGC Motherboard
Will intel D101GGC support SATA 250 GB with 7200rpm speed
Hello
Yes There are Four sata connectors on the board.250 gb at 7200 rpm is fairly standard.
Here is a link to your board for future reference.
http://downloadmirror.intel.com/15113/eng/D101GGC_ProductGuide_English.pdf
Jan 18, 2011 | Intel D101GGC Motherboard
Hay, i just wanted to know wheather intel d101GGC supports ddr2 ram.and also needs to know wheather the board supports the sata harddisk
This motherboard does not support DDR2 RAM but this motherboard supports SATA hard disk
Reference: http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
You need to have adobe reader installed in your computer to read the pdf file from the link above
Nov 14, 2010 | Intel D101GGC Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Can i instal sata hard disk in intel desktop d101ggc
Yes, according to the manual the board has four SATA interfaces. SATA is backwards compatible, so the only risk is not to get the maximum speed. Be aware that if you are replacing a drive, the set up procedure might require initial drivers before setting up the OS. You will need also 1 piece of SATA cable, fout bolts for attaching the disk, and maybe a power adapter joint if the disk has just newer standard socket and your power supply does not have such jack. If you are installing the disk as a second drive for storage, the set up will be far more easy.
Nov 11, 2009 | Intel D101GGC Motherboard
Intel D101GGC freezes ramdoly
Well, these kind of problems are very tricky to diagnose. You said that you've tried replacing your RAM, HDD and also the Power Supply. If you're using multiple RAM modules for dual channel support, remove one of the modules and try to run the system with only one module in the slots. If it still doesn't work, try to switch the RAM module to another slot. Do the same with the second RAM module.
It can also happen if the IDE/SATA cables are faulty/worn out. Inspect them to see if any of the pins are loose/broken.
Another way to diagnose problems with HDDs is
1. Disconnect your Hard Drives completely,
2. Boot your computer with a Linux/XP live CD using your CD/DVD-ROM drive.
3. If it runs perfectly, then you can assume that the problem might be with the HDD or the SATA/IDE cables.
Let me know the results after you troubleshoot.
Aug 19, 2009 | Intel D101GGC Motherboard
SATA dvd writer doesnt works with D101GGC
you have another sta device conected in your pc?
go to the bios to see sata configuration chip.
i think there is to resolve your problem
Apr 07, 2009 | Intel D101GGC Motherboard
Computers & Internet Logo
289 people viewed this question
David Payne
David Payne
