Question about Garden
Looking for diaphram for self oiling on 101av stihl chainsaw
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
My stihl chainsaw leaks oil from behind the muffler
there is a small plug that is on the chain side of the saw that is at the bottom corner by the muffler. look and see if that is where it is coming from. if it is then you will have to take it to a Stihl dealer for repair
Sep 23, 2014 | Stihl Garden
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
Need to know the oil to gas ratio for a 056 stihl chainsaw?
Stihl chainsaws are 1:50 oil to gas ratio. Make sure you use good high-quality 2-stroke oil, preferably that which is made by Stihl.
May 21, 2010 | Stihl Chainsaw 045 056 Clutch Chain Saw...
Will start, but bogging down. was told its the diaphram in carburator, worn or just dirty
do you have right fuel/oil mix look on fuel cap for ratio is it old gas when is the last time you cleaned air filter sounds like its starving for fuel take air cleaner cover off also filter try starting clean filter with warm soapy water squeez out extra water let air dry also lawn mower shops have your sprocket
Apr 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Chainsaw gas/oil mix ratio
I have two Stihls that are well over 20 years old. I use the factory recommended mixture, 1 part 2 cycle Stihl oil to regular gas. (1:50)
That is still what the factory recommends. Don't use a cheap 2 cycle oil, go to a Stihl store and buy their 2 cycle oil in the orange plastic bottle.
Jun 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
