Question about PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive
My imation USB does not work ! When I insert it
Hello
My imation USB does not work ! When I insert it into my computer it just says I need to format it in Drive H !
And when I check the properties it just says it is full with zeros in the used and empty spaces ! Have I lost all the files forever ?
  • 12,061 Answers
Maybe NOT try this in another PC, often that will work, if so, try this., below. Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Posted on May 09, 2010
  • 68 Answers
Scan it with a updated antivirus and then right click on it and explore it when it opens copy all the files in any folder on the drive and then format it and then insert the files
if u have still ur problem then call me
vicky
+919584011072
Format imation defender F150
Connect it to your computer.
Open "My Computer".
Right-click on the icon for the device.
Click "Properties".
Click "Tools".
Click to 'format' it.
Jan 23, 2014 | Imation Defender F150 8GB USB 2.0 Flash...
My flash drive is imation but it shows copy write protection when i try to format or paste there.
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
click start click on my computer to open you should see your drive
right click then select format
another way
click start control panel administration tools computer management disk management right
right click on your usb drive select format
if you need more help with this post a reply
hope this helps
Aug 05, 2012 | Imation Electronics - Others
Pen drive memory problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
the right click on your drive select properties you will see how much data you have and the ammount free space
hope this helps you
Jan 12, 2012 | Imation Electronics - Others
I have an 8gb imation that become 4mb free space why it happen?
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Nov 11, 2011 | Imation Products - imation - Clip Flash...
I cannot format my imation usb flash drive i tried formatting in on windows 7 but unable to complete format it says
connect your usb flash drive to a computer then double click the drive and delete all the contents then click properties then click tools then click check now and see wether the hard disk is having anf fault then close it and right click the drive and click format check the quick format method this will format the drive
Oct 26, 2011 | Computers & Internet
Hi, I had problem using Imation 27390 apollo expert ux. The hardisk is in NTFS format, and work perfectly fine when i plug in computer with Windows Vista and 7. But it cannot be recognized by computer...
Windows XP has limitations on recognising too large NTFS disks. One of the solutions would be to format the entire disk as FAT32 or make a partition and format that as FAT32.
Feb 28, 2011 | Imation 27390 Apollo Expert UX 2.5" 320GB...
Imation USB not reading in My Computer
Insert the device and restart the computer. Does it shows a "removable disk" icon in My computer? If it does, go to the properties and click unblock, may it's block. If that doesn't work, then just reformat.
Sep 05, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
PQI 512MB Intelligent Stick USB 2.0 Flash Drive (437353) Hard Drive Logo
253 people viewed this question
Top PQI Computers & Internet Experts
William Alequin
Ruben Balisbis
Ruben Balisbis
Are you a PQI Computer and Internet Expert? Answer questions, earn points and help others
