Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE GSH25JSRSS not dispensing ice or water, relay clicking, no start, no cool.
You advised others that it could be a bad compressor, but one was advised that there could be a reset button on the compressor. will my warranty be voided if I open the enclosure and push the reset button myself? I am a fairly qualified button pusher and an electrician. What do you think?
Thanks, litewiz
    President:
  • GE Master
  • 2,651 Answers
Its not as easy as pushing a button, theres actually an overload/relay attached to the side of compresssor. you can replace the part. it might be it, however sometimes a bad compressor will blow the relay, instead of the relay saving the compressor. probably 50-75 bucks for part.
Posted on Mar 28, 2008
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
May 20, 2009 | GE Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Nov 07, 2008 | Jenn-Air JCD2389G Side by Side...
My GE Refrigerator Clicks for hours but will not start.
Clicking you describe sounds like a bad motherboard. Water dispenser issues have been result of frozen water in the tubing in the bottom of the FF area, which you should not have at the moment, so if it is not dispensing water now I'd check the water valve coil. (there are two coils on the inlet valve, one for the icemaker and one for the water dispenser.)
Sep 26, 2008 | GE GSL25JFR Brushed Steel Side by Side...
Not Cooling
sounds like its trying to restart, and clicking off in 30 secs or so???? sounds like a relay on the compressor assy.indicator of bad compressor. shloud be under under 5 yr warr with the manufacture. ck your manual for specifc warr information,
Mar 23, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
158 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
