Question about Summer Infant Day & Handheld Video Monitor 2.5 In Screen
My video monitor screen went dark no video. video was on most of the day I , looked up and screen was dark no visible video of child. No battery used plugged into outlet. Other monitor still working.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
Nov 16, 2017 | Samsung Televison & Video
What would cause dark blurred display all modes?
I suspect the monitor is dying. Unless it is under warranty, you may need to replace it, as getting it fixed may cost more than a new one.
Jul 25, 2014 | Samsung 22" TFT SYNCMASTER P2250 LCD...
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
This Formac monitor had some screen brightness issues for some time and then one day just went dark. The video card is ok, because it drives other monitors just fine. I checked the formac power supply...
was you check your monitor cable??maybe it because your monitor cable didn't connect properly
i hope this helpfull
please rate my answer
thanks
Dec 24, 2010 | Computers & Internet
My monitor went dark for no visible reason. I
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Gateway 3522GZ display
Some searching on forums convinced me the inverter had failed. Picked one up for $65, removed the frame around the screen, removed the mounting screw for the inverter, and unplugged both ends of the old and plugged in the new. Put it back togeher and fired it up, bright again. Key here was that a remote monitor still worked which meant video card was OK. The lamp could have been bad, but apparently the life of lamps is pretty decent.
Aug 31, 2008 | Gateway 3522GZ Notebook
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
LCD Monitor went Dark
hi bear2243055
I suggest reinstalling your graphics device drivers and maybe the game as well.
May 08, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Summer Infant  Day & Handheld Video Monitor 2.5 In Screen Logo
544 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
