Pls can someone help me. I am having difficulty port-forwarding my router: Engenius EOC 3220. I have tried all i can, even bought a software from www.portforward.com website but still didn't work. Is there an alternative? Thanx
  • Bill Castor May 09, 2010
    Thanx alot man. . .
  • 12,061 Answers
This is NOT really a "Router" as such, it is an "Access" point, or "Client Bridge" It is described as:- The Outdoor Wireless Client Bridge/Access Point/WDS (wireless distribution system) You cannot use any sort of port forwarding as this is NOT how it works, actually, all "Ports" should be put through, It will be your firewall that will be stopping anything not this. You need to read the manual I have given you the link for. Inside you will see how to set it up, it would be best set as an "Access point Bridge Mode" in doing so ALL traffic should be passed on to the Ethernet port. This is usually used as well as a router, and then the router or software does all the port forwarding. You may find, that your ISP is blocking ports? and not you PC's firewall ? As said you need to read and understand your manual.
http://www.netgate.com/info/NOC3220/UserManual.pdf
Posted on May 09, 2010
My Seneo 3220 has changed its mac and gone to Realtek,can not log on to it any more,think its lost Engenius software. nigel 2205
I have no idea what it means for a Senao to "go to Realtek."
Here is the factory reset procedure for the Senao EOC-3220:
An RS-232 null modem serial cable is required for this procedure.
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Oct 25, 2010 | EnGenius EOC-3220 (EOC3220)
Unable to connect to eoc3220 thru serial or network, any ideas
If you can connect to another, known-good EOC-3220 using the same serial cable and software setup, then your other EOC-3220 is probably just blown. It happens - I have several in a box in the workshop. :-(
Oct 11, 2010 | EnGenius EOC-3220 (EOC3220)
I have EnGenius EOC-3220 (EOC3220) i can not reset with my null serial cable please help me
Depending on the serial cable you have, you may need a modem (crossover) adapter between the cable and the EOC-3220. A good diagnostic is the following: with the EOC-3220 unplugged from power, connect your serial cable and make all the proper baud rate etc. settings in your serial communications program. When it is running, plug the EOC-3220 into power. If you don't see any garbage characters appear on your screen when you plug the power in, your comm program is probably not set up properly. If you see garbage characters but they are not immediately followed by good information from the EOC-3220, then you either need a null modem adapter inline, or you have a dead EOC-3220. If you've never communicated successfully with an EOC-3220 before over the serial channel, the only way to know if you have a dead one is to try again with a known-good one.
Aug 12, 2010 | EnGenius EOC-3220 (EOC3220)
Can not get into the 3220 by ip or serial port
i forget my user name and password of my eoc 3220 router please how can i reset it
Aug 05, 2009 | EnGenius EOC-3220 (EOC3220)
Cannot get in to my Engenius 3220 with 192.168.1.10
Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping 192.168.1.10. If it answers, browse to 192.168.1.10 and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, 192.168.1.10 is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
http://engeniustech.com/datacom/support/general-details.aspx?id=65
If the ping and browse succeed, then make sure that 192.168.1.10 is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
May 02, 2009 | EnGenius EOC-3220 (EOC3220)
Antenna
First off, the EOC-3220 series comes in two choices: the ones ending in EXT, which require you to add an external antenna, and the ones without, to which there is no place to add an external antenna. So there is no decision to be made in the software configuration, because it's all handled above the software's pay grade.
Other Engenius models with "either/or" antennas come with a physical switch that allows you to choose between the internal antenna and the external jack. So again, there's no software contribution.
Oct 18, 2008 | EnGenius EOC-3220 (EOC3220)
EOC-3220ext Loosing its wired connection with lan
Try to Flush DNS Cache
ipconfig /flushDNS
Also
May 08, 2008 | EnGenius EOC-3220 (EOC3220)
Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
Apr 18, 2008 | EnGenius EOC-3220+ (EOC3220PLUS)
Resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Feb 21, 2008 | EnGenius EOC-3220 (EOC3220)
Needs reset
Don't use Engenius...there tech support is terrible and that is very mildly put....I don't use them anymore.....
Nov 30, 2007 | EnGenius EOC-3220 (EOC3220)
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
