My Zanussi Timeline 1600 will not start on any program. When I have selected a program the first thing that happens is the macine drains, then after a short delay the temperature and rpm display show zero and the cycle ended message appears. I have cleaned the drain filter to no effect.
  • jezwadd May 09, 2010
    When I first start the program, the display shows "washing" and there is a hum as if something is trying to start. After a delay of around 5 seconds, the display very briefly shows "spinning" and then "draining" with the temperature and rpm display showing zero followed after a further 5 seconds "cycle finished"
    Thankyou for all the info. I will check it out.
  • Washing Mach... Master
  • 19,396 Answers
Hi.
When the cycle start the machine is supposed to be filling rather than draining. If the machine starts draining, that means that there is water remaining from the previous cycle, and that the pressure switch is defective.
Disconnect power and check if there is water in the tub before the cycle is starting.
If there is water, then the pressure switch is defective. Pressure switch is tested by jumping it or opening it and testing cycle. Test must be done by a technician.
If the pressure switch is OK, then the faulty part is the timer board. Draining at start of the cycle is quite unusual.
Also ensure that what you think is draining at start of the cycle is not just filling. In that case if the machine is not filling properly, the inlet valve and inlet lines must be tested.
Inlet valve is tested reading Ohms at valve solenoid contacts.If it reads infinite, then the valve is faulty.
Regards.
Posted on May 09, 2010
  • Ginko
    Ginko May 09, 2010
    The humming noise is probably the inlet. The timer board will jump to drain if one of the cycling conditions is not met or if the electronic control board is faulty.
    The repair is done testing all parts that can be involved, and then replacing timer board only if other parts test good.
    Before starting trip the circuit breaker or disconnect the power cord for five minutes and see if this simple reset changes anything.
    First part to test is the inlet.
    This can be done by the user.
    Check if the inlet hose is kinked or blocked and ensure that there is water pressure.
    Grab a multimeter, set at Rx1, disconnect inlet valve terminals and read Ohms at valve terminals. Test must be done with power NOT connected. If Ohms stay on infinity, then the valve is bad.
    Try to see if machine is filling. The tech may jump the door switch to observe cycle operation. For safety reasons this cannot be done by the user.
    Test water heating.
    This is very simple. Test a cold cycle. If machine works, then the thermostat or heating element must be replaced.
    Test water level sensing.
    From now onward more advanced tests that must be done by the technician, as they involve working with power on and jumping contacts.
    Zanussi washers use two pressure switch. One to pre vent overfilling and one on the drain system. The tech can test them by jumping contacts and controlling the cycle.
    If the machine is filling regularly, the motor must also be tested. This is done energizing the variable speed motor directly.
    Motor control unit, that is a module sealed inside the appliance must also be tested by reading voltages.
    If all the above is clear, then replace the timer electronic control assembly.
    Try also contacting Zanussi at the number listed on the user manual. They can give you part prices, quote on repair, and they can follow you on basic phone troubleshooting.
    Regards.
    Ginko.
I have a zanussi 1600 aquacycle. We had a power cut then the machine wouldn't empty so I emptied it manually and now the door won't lock to start any programmes. Any suggestions??
turm the power off
then press in the two buttons on the left hand side while pressing them turn power back on turn selector to one oclock{if you have buttons to select programs press it } you should see the lights come on and move to different programs this is a test program to take it off test turn to off then turn anti clock wise
Feb 03, 2015 | Zanussi Washing Machines
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Hi, I have a Zanussi Timeline 1400 front loader and after it has completed a wash, it will not do another wash for some time. If you select a program it will think about it and then say it is complete with...
Try this..
Reading Error Codes
1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up.
Jan 30, 2011 | Zanussi ZWF1450W Front Load Washer
My zanussi 1600 aquacycle will was but not drain
it sounds like have a bad water pump
Feb 24, 2010 | Washing Machines
My zanussi timeline 1600 washing machine has problems draining. Is there a way to fix this easily?
I suggest that you check and clean the filter.
This should be located at the bottom front right of washer behind drop down cover or flap. Unscrew anti-clockwise to remove and clean
Please rate my solution.
Thankyou.
Jan 16, 2010 | Zanussi ZWF1650W Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
