Question about Garden
My stihl chainsaw won't start. It has a good spark but fuel isnt getting through. It is filled with fresh fuel
Will fire,wont stay running.wants to be full choked,open choke,it dies
Jerry, First thing to get is a new plug gaped correctly and try. Could need carb. adjustment, fuel filter replaced, bad fuel line(cracked/pinched), Dirt/faulty diaphragm in carb. plugged spark arrester in muffler,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://answers.yahoo.com/question/index?qid=20090528073906AA0y882
Chainsaw will only run with choke
Stihl Chainsaw starts but won run
http://tekindoor.com/miscellaneous/stihl-chainsaw-troubleshooting
May 28, 2016 | Garden
Stihl MS180 chain saw wont start
How long since it was last used? Could be stale fuel. Flush tank, fill with fresh fuel and try again. May take a good dozen pulls to clear the fuel line. If not that then check spark by removing plug, connect to lead and hold electrode end to cycl head while pulling it over(might need a second pair of hands, don't do it if theirs fuel every where!) either that or it's flooded. Turn choke off, hold throttle wide open and pull it until it starts.
Sep 06, 2015 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
I have a 026stihl that won't start
It would be a good idea to check the compression first to make sure there is enough to make the saw run. A person can run in circles trying to figure out an issue if the compression is below 100 psi, there should be about 150 psi. Older Stihl saws are also notorious for cracked fuel lines. Check the fuel line to be sure it is ok, also check the spark.
Aug 04, 2011 | Stihl Garden
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl 021 is hard to start, runs very briefly after ignition.
My guess is since you have ignition, it is a fuel issue: 1- the carb or the fuel lines or pump are plugges with dirt, 2- fuel pump is not working,3- carb needs cleaned 4- air filter is plugged which is very common also. When the saws sit for 6 months or so, the cylinder tends to get gummed up cause our gas is SO good & when this happens with one of my saws, I put spray lube in the spark plug hole & turn it over. When I am thinking, I store my saws with the gas tank down, so that gas isnt running into the carb/engine.
Apr 11, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
