Question about GE 29439GE2 Corded Phone
Thunder hit phone gone out
One night a thunder hit our home and since then the phone is not working........... the use light does work so does the display but we cant hear any dial tone...we put another phone there but that phone worked.so i think its the problem with our g e phone
SOURCE: Tone Pulse
1)Make sure the phone is OFF (not in TALK MODE) 2)Press and hold the PROG buton until you hear a beep. The TALK button will flash while in this mode 3) Presd the TONE (*) button to select Tone Dialing or press the PAUSE (#) button to select Pulse Dialing 4) Press the PROG button again. The unit beeps to confirm.
Posted on Aug 17, 2007
  • 4 Answers
SOURCE: When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
Posted on May 08, 2008
SOURCE: GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Posted on Jul 20, 2008
SOURCE: Phone Not Working
I have had the same problem before and now again for the last week...I finally remembered what I did last time to solve it!
I put my "unavailable" Handset into the main cradle and left it there for a slow count of 20. That has reset the unavailable handset and returned the dial tone etc.
Maddening isnt' it!
Posted on Aug 03, 2008
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Can't get channel manager to come up. Can't change channels. Electric went out from a thunder storm. Transformer hit by lighting. Now can't get channel manager to come up and can't cha
If you have not tried it: UNPLUG THE SET FOR A WHILE then plug b a c k and see if helped-----what can happen if power outage is microprocessor in set gets confused.
Let me know if questions or if this helped.
Mar 23, 2012 | Hitachi P50V702 50 in. Plasma HDTV
My thunderace has gone dead on starter button, it has a datatool alarm, it will start by joining the solenoid, have checked all modules, sol ok, start btton &wires good,contenuity ok, everything else...
do the lights dim when you hit the starter button if not the button itself has no more contact inside sometimes the can be cleaned remove the pod from the bars remove retaining brackets inside pod that hold the wires in place be carefull not to lose the small spring clean contact and reasseble
Jan 29, 2010 | 2000 Yamaha YZF Thunder ace 1000 R
After thunder all my digital channels have gone when i do a search it cannot find any channels says no signal
mostly if thunder hit the anttenna or satellite receiver, the tuner module will be affected , so try changing this module might solve your problems.
Jul 09, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
While is my phone keep saying out of range
Call 310-953-9028 and GE tech support will walk you through the setup... hit the program or mute key on phone go to handset hit program/mute key to select, scroll down to select registration, hold down the page button from the home base for 5 seconds... then hit program/ mute again. It did not work for me, but the tech support said to charge phones for the night and try the process again tomorrow.
Jul 17, 2008 | Lands Phones
EXTENSIONS DON'T RING IN NIGHT MODE
A solution depends on what you are trying to achieve. Usually they are set up this way so when everyone has gone home the calls go to the voice processing system. If you have people working later, it would be easy to make night mode start later via system programming, which is program number 102 .
Feb 05, 2008 | Panasonic KX-T7453 Corded Phone
Night Service Button
Sounds to me like "inspect" might be the button programmed on the phone. IF the button is labeled "night" then you can reprogram the button.
press "SPKR # 0 0"
Press the button labeled "Night"
Press "* 3 9"
Then press the "home" or "exit" button.
See if that works...
Nov 28, 2007 | Lands Phones
GE 29439GE2 Corded Phone Logo
70 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
