Question about Asrock K7VM4 Motherboard
Nothing on screen, fan running on processor, hard drive trying to load OS
Same problem as Patatas. Some time ago I couldn't get the operating system to load. The machine would fire up but at this stage I did have something on the screen. I thought it was a bad sector on the hard drive so I reformatted and everything was fine for about a month. Now the screen is blank again and when I go into the screen menu it tells me that 'no signal' is being received. I have taken out the graphics card (which has worked perfectly up to now) and tried the on-board graphics port but still nothing. Have tried another monitor - nothing. Have bought a new hard drive - nothing. Given that the hard drive is firing up I have discounted the PSU (am I right to do so?). There is a second hand K7 VT6 Motherboard for sale on e-bay - would this be a reasonable replacement? Thanks
  • 1 more comment
  • Eagleboy Mar 29, 2008
    The original problem was appeared to be a bootstrap problem - it would get to log-in screen in Windows then re-boot. I thought it could be a bad sector on the hard drive so I reformatted and re-partitioned the hard drive and re-installed Windows. Everything was fine for a couple of months and then the same problem occurred except that this time, after a couple of forced re-boots using the power button, I got three long beeps and then nothing on screen. Checking on the monitor menu it says 'no signal'. I removed the graphics card and tried the on-board graphics port but no joy, (I could not get into the Bios because obviously I have got no screen). I am not getting any error beeps when I power up.
  • Eagleboy Apr 02, 2008
    I've now replaced the motherboard, fan, heatsink and PSU and am still getting nothing on two screens that were working previously. I get a single beep from POST. I have checked to make sure the I/O panel is making contact and it is, and have checked the cabling - all lights coming on to Power On, DVD and hard drive. No problem with cooling as PC is running with the Asrock COP kicking in. The only thing I haven't replaced is the CPU and I don't think that's the problem? Any help guys would be greatly appreciated. Thanks
  • Dave MacPhee
    Dave MacPhee May 11, 2010
    Let's not go for a new motherboard yet.. First, when you say blank screen, where does this occur? Where do you see the "screen menu"? Also, please post the bios version you have...
    Most likely, if the fans are running, and the HDD and CD powers up, it is not the PSU...
  • 99 Answers
Did you try to replace your memory? do you hear a sound (click) once only,when you open your PC? if none, pls..try to replace your memory.but if still nothing happen,then thats the time to replace your Main-board.
Posted on Mar 29, 2008
How do I wake a sleeping hard-drive on my pc
possible hard drive failure, try shutting machine on and off consecutively 10 times, to get running.
good luck
Jan 17, 2016 | Seagate Barracuda 7200 1.5 TB 7200RPM SATA...
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
My computer came up with a blue screen that said system error said something about a physical memory dump and that it is shutting down the computer to keep me from losing my files, that was all I got from...
Not necessarily. This usually means an error somewhere in the critical operating system files. whether this is software problem or hardware remains to be seen.
Assuming that you will, sadly; not be able to access the operating system again, you can still access the files and get a back up using a hard drive adapter: http://www.coolmaxusa.com./productDetails.asp?item=CD-350-COMBO&details=overview&subcategory=converter&category=converter
This does involve having another pc to load the files onto. Once the data is backed up a format will indicate if its a hardware issue but hopefully the format will manage any bad sectors. Once the format is complete the hard drive can be placed back in the laptop and an OS can be reloaded.
This all is if you wish to backup, you can just load in an OS cd/recovery disk and let it format the drive and just Install rewriting over any data and formatting around any potential bad sectors on the drive.
Feb 04, 2011 | HP Pavilion dv9000z Notebook
Windows XP unable to load os on hard disk
Hi Friend,
You need to select your first boot option. it should be hard drive not a bios. if your system not restart then you need to restore your system...
Dec 28, 2009 | E-Machines (T2958) PC Desktop
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Gateway screen comes up; optical and (new) hard drive spin up, both drive lights light up during this time, fan spins up and air moves out of the side vent continously but still nothing but a blank screen....
If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
Jul 05, 2009 | Gateway MX6931 Notebook
Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Mar 03, 2009 | Toshiba Tecra M2-S730 Notebook
Toshiba Qosmio same problem as above.
you need to add new silver thermal paste to the video chip (GPU)... then uncheck both options from your turbo memory console.... that will "unclock" your video card ... and your pc should run smooth
Sep 04, 2008 | Computers & Internet
Installation of operating system
The picture is misleading. Haha anyways, Its really simple to install an operating system. All you need is the installation CD and proper installation hardware such as (DVD, CD, or DVD/CD rom). Along with a hard drive. Now before installing an "O.S" follow these simple steps:
1-make sure its compatible with your motherboard, some motherboards are not compatible with certain versions of O.S.
2- you have to make sure, your processor is capable of the running the O.S you plan on installing.
3- You have to make sure you have enough Ram to run the O.S (the Ram and processor both have to be compatible with the motherboard to begin with).
4-Make sure your Hard drive is capable of supporting the O.S by having sufficient space to satisfy your needs and the O.S itself.
Once you have followed those steps you can follow the on screen process provided by the O.S installation CD.
In your Case this is what you would need.
A motherboard suitable for the processor you wish to use.
16Mb of ram or more (a single 32Mb ram stick should do).
A Hard drive of atleast half a Gig (i would recommend 10Gig or more so you can store more files).
Apr 22, 2008 | Sony PlayStation 2 (PS2) Compact System...
Hi Eagleboy, I wouldn't suggest buying a board on ebay. If things do not work out you'll spend more for shipping to & back just returning it rather than buying a new AGP4x video card.
You can double check the AGP slot. Get a strong flashlight. Look down into the slot, check for bent copper retainers, dirt & dust. You can also check & make sure the retainers almost touch each other from their oppsite sides. This is where you can help the AGP card get a tight fit. Clean both the AGP cards copper contacts & the slots copper retainers. Use house hold alcohol & some cotton swabs. Blow out the slot well
I'm guessing that you set the bios up correctly when you were using the AGP card & reset the bios when you went back to using the MB's VIA UniChrome Graphics. I agree with you, no need for a new PSU or HD. Shame you can not test your AGP card in another PC. If you can't do that than buy another AGP4x card & install it. http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=879&Nav=|c:318|c:694|&Sort=0&Recs=10
This is all a suggestion. If you feel the board is bad & replacing it sits well with you. (Do what you think is best).
Here are some compatable boards I have come across. I am unaware what CPU you are using.
http://shopping.yahoo.com/p:ASUS%20P4T533%20Motherboard:1990997820
http://www.pcupgrade.co.uk/productdetails.asp?ProductID=3576&categoryid=261
http://www.google.com/products?hl=en&resnum=0&q=motherboards+socket+462&um=1&ie=UTF-8
Good Luck!
If there is anything else I can do, just ask.
Mike
Mar 28, 2008 | Asrock K7VM4 Motherboard
Asrock K7VM4 Motherboard Logo
107 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
