Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer won't advance to next cycle. I think the problem is with timer. It works when I advance the timer manually. How do I change the timer and what is the part number? I have Whirlpool SAQS800HQ. Thanks!
  • 269 Answers
It may not be the timer,before you go down that costly road,check the water supply and see if it is filling through both valves or it could be a heater fault.
Is it filling slowly or draining slowly check.
Posted on May 09, 2010
I have a Maytag Ensignia washer that will fill with water and start working but will not advance to the next cycle without manually advancing the dial. once helped into the next cycle the washer works...
First you need to list the model number in order for me to figure out what type of washer it is then i can help you. The reason I ask is some Maytag Ensignia's come with electronic timers and some models have old style timers...
Mar 10, 2013 | Washing Machines
Whirlpool top load washer won't advance through cycles
A small motor that rotates the timer has gone bad. Common practice is to replace the timer. Usually a mechanical timer of this type is less expensive than a computerized timer.
Mar 14, 2012 | Whirlpool LSB6300PW Top Load Washer
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My washer won't change cycles on it's own. I have to change it's cycle manually. What do you think is the problem?
well if your saying that when you select a cycle and start a load andtrhe washer timer isnt advancing to the end of cycle then you have a timer problem...... but if it stops before rinse and spin in every cycle i would say you have a bad lid switch...
Jan 24, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not advance to next cycle
need to replace that timer
Feb 05, 2010 | Washing Machines
Washer will not move to next cycle; has to be done manually
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. Hope this helped.
Jul 16, 2009 | Washing Machines
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
My washer was working fine and now does not go through the cycles
the timer is not advancing by its self...defective timer replace..onthejob
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Won,t drain on rinse cycle
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
148 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
