Question about Sony Cyber-shot® DSC-H20 Digital Camera
Is there panorama option in dsch20 sony camera
  • FIKRET UNALIR
    FIKRET UNALIR May 11, 2010
    Your camera has no such ability. But If you want to take panoramic pictures I can tell about it if you want?
  • mina boveiri
    mina boveiri Nov 17, 2013
    Please tell me about how I can take a panorama pictures.
The flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Jan 10, 2010 | Sony DSC-T70 Digital Camera
How to activate panorama?
Panorama shooting lets you create a panoramic picture, using the OLYMPUS
Master software from the provided CD-ROM. An Olympus xD-Picture Card is required for Panorama shooting. If the card is a Fuji xD card then the panorama feature would be disabled to you.
May 24, 2009 | Olympus Stylus / mju 1050 SW Digital...
Quick question - just bought my sony H50 today and can't figure out how to do panorama shots. Does not say in the manual. Do you know how? Many thanks ! Lisa )
Sorry, unfortunately the H50 doesn't have in-camera panorama stitching... you'll have to just take a series of shots and use something along the lines of Adobe Photoshop Elements to stitch everything together - the closest I could find was a 16:9 setting within the camera, but that's just a close crop, it doesn't produce a true panoramic shot.
Please rate this solution if you've found it helpful! Thanks!!
May 12, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
I have the Olympus C-4000 Zoom and am having difficulty getting into the panorama mode which I really need for business. What am I not doing right.? Johnston. Spain.
First of all you need to be sure you are using a memory card that is an Olympus card. If it is a non-Olympus card then the panorama option will be disabled to you.
Then go to Menu - Mode Menu - Camera tab - Panorama option and select right arrow. This should enable the panorama mode for the camera.
Apr 29, 2009 | Olympus Camedia C-4000 Zoom Digital Camera
I have new olympus 850SW with the required Olympus xD picture card, 1 GB & can't access the in camera panorama...I know I did it once but it is grayed out now - only pano on PC available...I've read...
To access the panorama mode in the camera you need to be in P mode.
To set the P mode you need to press the Ok button right arrow to P for Program Auto and press Ok. Then as long as you are using an Olympus xD card you should be able to go to menu and highlight the Panorama option.
Oct 05, 2008 | Olympus Cameras
Hello, i can't get the in-camera panorama options available. i have a 2gb memory card inside with 310 pictures left (on fine picture and 8mb size). What do i do?
make sure the camera is in P mode for panorama... press the ok button and change from auto to p mode. also for panorama, it does require an Olympus xD card.
Sep 02, 2008 | Olympus Cameras
I just got the olympus 850 sw and one of the reasons I got it was for the panorama feature. I have the right xd card to unlock it, but I can only get the pc option to work. What setting does it need to be...
Spin the selection wheel to "camera" mode. Press th middle "function/ok" button on the back. the first selection is AUTO or P "program". The default is AUTO...change it to PROGRAM. It needs to be in PROGRAM for it to work. I just figured it out...it works great. Good Luck!
Jun 29, 2008 | Olympus Cameras
C-450Z - can't take panoramas
Olympus has a special format for his own card so when you buy a original panorama XD card it will works properly. When you format a normal unknown brand card in the Olympus it will not change to a panarama type
Sep 12, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Panorama mode?
The panorama mode SmartMedia cards are special function cards sold only by Olympus. I had a 2mb card with this function with my C-820L, however, I found that the panorama software available from companies like LivePicture and others works much better (and is much easier to use), than trying to use the special function card to do the same thing. With the panorama software instead of card, you can use anyone's SmartMedia. Did you buy your C2000Z here in Europe? I'm interested to know what software (if any) was included. I bought mine in the States and brought it back; it included panorama software from Enroute Imaging called "QuickStitch". I haven't used it since I already have "PhotoVista" from Live Picture. The other reason I opted not to use the special function panorama card from Olympus is that it requires the LCD viewer to be on while shooting; as you probably are beginning to discover, the LCD eats batteries, so I avoid it at all possible costs to try and conserve them.
Sep 11, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
Panorama picture
You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Sony Cyber-shot® DSC-H20 Digital Camera Logo
297 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
