Question about Canon PIXMA iP3000 InkJet Photo Printer
My printer power wont turn on when i press button
My printer canon pixma ip 3000 power wont turn on when i press button though supply is good
    Problem Solver:
  • 5 Answers
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
Posted on Jun 06, 2010
  • Canon Master
  • 12,061 Answers
Http://printer1.blogspot.com/2008/01/canon-pixma-ip3000-service-manual.html
get your service manual above, you will be able to troubleshoot and hopefully repair your unit.
Posted on May 09, 2010
No imprime
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Jul 06, 2011 | Canon PIXMA iP1300 Printer
My canon pixma ip 3000 is malfuntioning, it flashes orange lights everytime I turned it on. can you help me what to do? thanks
Hi there!
Please try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt. If this doesn't work you can also try to reset the waste pad by turning the printer off. Then hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Then press Resume button 2 times then let BOTH buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more.
Hope this helps.
Mar 30, 2011 | Canon Pixma iP3000 All-In-One InkJet...
Canon printer ip 3000 keeps sending error 6c00? what do I need to do?
Try the following steps:
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Nov 19, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a canon pixma ip 3000 and i need to empty inktank can u help
Ther is no ink tank it is a counter pre set by canon who decided you can only print so many pages . it is artificial number.
reset your machine by the following should help
read all first
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
to fix also :
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
or: and Also;
Unplug unit, hold power and reset button down
THEN plug it in while still holding both buttons down;
Then to step 3 above.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
No print
Hi there you can try this.
Canon IP 2000 / 3000 INK counter reset
1. Turn off printer
All the best Pineworks
Feb 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Pixma ip 3000 power on all the time no functions. cannon
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Pixma ip6000d. Doesn't function except for the power lamp.Is there a reset or any thing I can check out.
You could try this reset procedure;
1. Turn off printer
I use it on my IP3000 to reset and it is meant to be for ALL Canon pixma ip 3000 and above, best of luck!!
Jul 04, 2008 | Cannon Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
639 people viewed this question
old marine
old marine
