Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
I have a Simpson 2W600W Fan oven, recently the Oven element stopped working so I replaced it, when removing the old one there only appeared to be 2 wires attached which I pulled through for easy reconnection, after replacing the element the stove heats up fine, however I have a problem of the oven light and venting fan switching on as soon as the stove is switched on this happens if trhe oven is used or just the hob anyone have any idea why this would happen
5 Suggested Answers
  • 833 Answers
SOURCE: SMEG CC92MFX5 STAINLESS STEEL SIDE BY SIDE OVEN
Two things sharyn, first check the breakers. It is possible that one of two that control the stove tripped...they are in tandem. Shut them off and back on. If no fix: You'll have to remove and test the element. (if more than one element is involved here...it might be the thermostat) Breakers off, pull the element out and have someone take an ohm meter and test the unit. Still no good? Then it will be the thermostat or relay. Let me know what you find.
Posted on Dec 07, 2007
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
  • 69 Answers
SOURCE: It would appear that the main oven element is not working
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Posted on Aug 10, 2009
sonicboomele
  • 1557 Answers
SOURCE: trying to change element on
pull the top forward and release the top please get back to me as to how many elements you have had to replace as i have one here in the workshop thats blown five in 2 yrs
cheers sonic boom
Posted on Oct 03, 2011
I need a owners manual for Simpson Concorde fan forced oven?
I recently helped a friend fix the oven in his secound home, turned out the timer was shot. But, in order to find this out, we had to pull the oven from the wall, and there was a wiring diagram in an envelope on the back of the oven. That is all that it took to figure out the problem.
Dec 14, 2014 | Ovens
Flavel cascade 100 fan oven not heating, but fan still going. Grill and other oven still work. Is the oven lamp in the circuit? That has blown so just wondered if the two things are linked?
Heating element has blown IRCA Type RL6 1800W Remove back panel unscrew 2 screws remove the 3 conected cables open oven door remove 2 screws at rear of oven that holds faceplate in place remove face plate and take old element out and replace with a new element
Oct 08, 2013 | Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
I have a hotpoint ew91 oven that stopped working after tripping house fuse. after resetting fuse fan works but no heat.
It is most likely that the oven heating element has failed which caused the house fuse to trip.
The replace the heating element will mean taking the back off the oven and removing the old heat element by undoing the fixing screws and the electrical connectors( normally this surrounds the fan assembly).
Fitting the new heat element should then be straight forward.
Remember to disconnect the power to the oven before removing the back.
Dec 09, 2010 | Ovens
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
Aug 10, 2009 | Smeg Ovens
Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Mar 19, 2009 | Ovens
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Oven element replacement- Simpson eziset electric
hiya
firstly make sure the power is isolated before removing any panels.
sometimes the element will just screw out from the inside of the oven and should pull through into the oven compartment with the wires attached, simply remove the wires, replace the element and refit any panels.
hope this helps
please dnt forget to rate the helpfulness of this reply thanks kj
Nov 11, 2008 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
126 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
