Question about NetGear RangeMax NEXT WNR834B Wireless Router
I want to set it up
I lost my cd that shows how to set it up with 2wire 2071-A modem and netgear rangemax WNR834B
moek10
SOURCE: NetGear RangeMax WPN824 Router
Is the smart setup (that is automatic setup) does not work, call your internet provider for the exact details (unless you have them) and do the manual setup.
You will save time.
Posted on Nov 14, 2007
sandrew
  • 2961 Answers
SOURCE: netgear rangemax wpn824
attach pc to router using the lan ethernet cable, switch on router, restart pc, then type 192.168.0.1 into your web browser, select admin as the admin and password as the password and then you should be in the routers menu.
Posted on Sep 03, 2008
kakee
  • 1268 Answers
SOURCE: Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Posted on Nov 25, 2008
  • 8404 Answers
SOURCE: i HAVE A NETGEAR RANGEMAX WNR834B - worked fine
Press the hard reset firmly but dont break it.
Can you use the transformer on a similar rated device to assure your trans is putting out the required volts - or - can you measure it with a volt-ohm meter?
I dont think there is a fuse inside, but you could open the case and check. Check the fuse with a contunity checker (volt - ohm meter)
You say the case has a tag that says you will void the warranty if you break it? Is there a warranty on it?
If you have a warranty, get it serviced. If the warranty is expired, duh, it dont work now and you will not make it any worse.
Let me know what you find out
a
Posted on Sep 25, 2009
Testimonial: "using a different transformer worked! Excellent suggestions! thanks"
How do you connect your netgear to the computer
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 13, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
I have At&T internet a motorola modem from them and a neatgear router rangemax WNR834B. AT&T helped me setup the wireless network. I think my router is bad since the power light does not light....
No solid power light = NO internet. Check and make sure router is plugged in. Try unplugging router for half a minute and plug it in again check and make sure the outlet works where you are plugging the router in and if still no power light you can contact Netgear support at 888-638-4327.
Apr 18, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Cannot access online through netgear
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Apr 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
This router is not working
Try the reset button to put it back to factory default. If it's still not working, it's time for a new router.
Feb 26, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How do you connect a netgear router from dsl to cable
The DSL modem will have a LAN port (RJ45), plug a LAN cable in this port and connect the other end to the Netgear router's WAN port.
Sep 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Lost internet connection
If that Toshiba laptop is not in use do you still experience that problem?
You may change wireless channel in your router.
Do a firmware upgrade for your router as well.
Hope this helps!
Nov 14, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Internet faliure
This is a problem with your modem, you can try to reset the modem then reconfigure it back using the setup CD but the best way to solve this and check the modem is to call Netgear tech support and let one of their tech walk you through with that process , this is the number 1-888-638-4327 ...
Hope that helps..........
Sep 15, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
