Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Brother intellifax 4750e
Ok, first it was at sleep. We changed the drum because it promted us to. But it is still sleeping and it still says change drum soon????
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Posted on Apr 18, 2008
How can we print a fax in memory from the intellifax 4750e?
Posted on Feb 25, 2009
MFC-7840w printer, how do i take it off sleep mode?
  • The control panel features a series of buttons as well as an LED "Status" screen.
  • Press the "MENU" button. Go to INITIAL SETUP, select "FAX" select "RECEIVE MODE" change to F/T
  • If you are using the Brother on a line by itself, set it to "Fax." If you are using the Brother on a line that also shares a telephone, set it to "Fax/Telephone." If you are using the Brother IntelliFax along with ananswering machine, set it to "TAD." Once you set your IntelliFax to the appropriate mode, the unit will leave "Sleep" mode and be ready for use.
  • Select "GENERAL SETUP" go to "ECOLOGY" and #2 is SLEEP TIME = adjust to 60 sec. This keeps the machine from becoming idle/sleep mode for a longer period.
    Sep 25, 2010 | Office Equipment & Supplies
    Just replaced drum unit in our brother 4750e intellifax, now makes horrible squealing sound when printing. Ideas how to fix?
    the drum is not set good please remove the drum and install it again something you do wrong.
    Check do the drum is`set good.
    Jul 15, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
    Speed Dial Setup on Brother IntelliFax 4750e
    pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Fax%204750e-5750e%20User%20Guide.pdf
    Apr 03, 2009 | Brother Office Equipment & Supplies
    My Brother 4750e promted: Machine Erroe 71 unplug machine and call service
    that error code points to your laser unit and unfortunately for you will require a tech.
    razors
    Mar 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
    Intellifax 4750e, prompted us to change the drum soon. We did change the drum but it is still telling us to change drum soon.
    We went to Brother website and obtained a manual and we were forgetting to reset the counter. Once the counter was reset, the message went away.
    Jan 13, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
    Disable sleep mode
    To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
    Jun 27, 2008 | Brother IntelliFAX 4100 Laser Fax
    if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
    Hope that helps...
    Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
    Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
    1,711 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
