Question about Samsung HLR5067WX 50" Rear Projection HDTV
Has a click under the seat when you drive forward
Has a click under the seat when you drive forward and does not have the same power. it sound like a drivechain however i do know that it is not the case. what kind of gears go under the back seat that drive the rear axles? and what do the gears look like. and can i change them on my own, i do have some experience with small engines.
    Brigadier General:
  • 4,090 Answers
Not sure how this relates to
Samsung HLR5067WX 50 in. Rear Projection HDTV Television has a click under the seat when you ...
Posted on May 09, 2010
Drivers power seat wont move forward. Can't push clutch if I can't move the seat forward
Check the two fuse boxes (use your smartphone camera and flash) for anything burned out . Note: There are two fuse boxes, one inside, under the dash and another by the engine.
Owners manual will help you locate the seat power fuse.
Dec 06, 2015 | 2005 Volvo S40 2.4
MY DRIVERS SIDE POWER SEAT WONT GO BACK OR FORWARD BUT ALL OTHER PARTS OF THE SEAT WORK FINE I CAN HEAR SOMETHING CLICKING WHEN I TRY TO MOVE THE SEAT BUT THE SEAT WONT GO BACK OR FORWARD
Check under the seat for broken wires. Forward and backwards is the function most used and causes the wires to bend back and forth. you may need to remove the seat for inspection or you may be lucky and see the problem just by raising the seat as high as it will go.
Aug 21, 2015 | 1998 Cadillac DeVille
How do I fix a clicking noise when powering front seat forward or back in 2004 Grand Cherokee?
Check the track under the seat just to make sure . Unfortunately it sounds like a gear and or motor failure.
Mar 19, 2015 | Jeep Grand Cherokee Cars & Trucks
Driver side seat will not go forward or backwards. Make a clicking sound. Wondering if the motor is going out.
The clicking noise is either from a cable or a cable to the Seat transmission under the seat. One of these parts are stripped out causing the cable to click in the seat transmission
May 31, 2010 | 2002 Ford Explorer
My 04 navigator left power seat wont move any direction and pedal adjust wont move...there is a clicking sound coming from a black box under seat but no function
it does not appear that the driver seat or adjustable pedal share anything in common
furthermore, the sound you hear clicking may be the actual seat motor trying to work, but lets do a quick test
try to move the seat up/down, forward/back and any combination. If while holding the button in said position and you consistently hear the clicking sound that follow the sound and touch the motor under your seat. If you feel the "clicking" then your seat motor is bound or siezed and will need repair.
if instead you just hear one click then you might be experiencing a relay problem
As for the pedal adjustment... have you checked fuse #109 (30A) @ the CJB (Central Junction Box) behind the right kick panel?
Apr 10, 2010 | 2005 Lincoln Navigator
2001 Volvo V70 drivers power front seat will move forward only.
if you hear a clicking sound from under the seat when trying to move backward then its not the switch. check the motor instead
Jun 02, 2009 | 2001 Volvo V70
Drivers electic seat will not adjust
I just had the same problem. When the seat is powered all the forward, one of the worm drives reached the end of its travel and jammed against the threaded block that it passes through. To fix this the seat has to be unbolted and tipped back. There are four tiny 6mm bolts that hold the motor plate in. Remove these and the motor will come out. The worm drive is bolted in at one end and has a set pin at the other. Remove the worm drive and use a couple of vice grips or equivalent to loosen the threaded block from the worm drive.
Mar 29, 2009 | 2002 Toyota Camry Solara
Bmw seat wont go back
The power seat uses DC motors. To change direction the polarity reverses from one direction to another. If you hear the motor "clicking" when you try to drive it forward, even though it is already forward, this signals the motor brushes are making contact to the commutator. So if it is "clicking" the problem is most likely the rearward seat movement switch itself or bad connection from the seat switch to the motor. If there is no "clicking" sound, this indicates no power is reaching the motor, it is most likely hair, dust or trash that has entered the motor and become lodged under the brushes, preventing failure of the electric circuit to the commutator. Unbolt the seat, remove it from the car and be careful with disassembly and cleaning of the motor, they can be difficult to reassemble as they have permanent magnets. I am not certain on your BMW, but many manufacturers use a motor with an open end that you can manually rotate the motor by hand with a piece of square key stock, this may also dislodge any debris stuck under the brushes and allow the motor to operate.
Jan 19, 2009 | 1999 BMW 328 Series
Samsung HLR5067WX 50" Rear Projection HDTV Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
