Question about TruTech PLV1615T 15 in. LCD Television
Lcd tv no power
Is there a source for procuring a power supply curcuit board for the above referenced tv?
    Champion:
  • 367 Answers
Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.So far I have fixed four of the same make,and model TV as this,and they all had either one,or two bad capacitors.I hope this helps.If you have any other questions,please let me know.Thank You very much!
Tyler
Posted on May 21, 2008
SOURCE:
Polaroid TLX-1911C LCD TV with no picture (black screen) and sound. Which board do I replace? Power supply or Main board?
I would first check the power supply. Check the main fuse, if is blown and there was no power surge from an external source, the supply board has some serious problem. If the fuse is fine measure the output voltage of the power supply board. Check for any swollen electrolytic capacitors, they are the number one cause of every LCD failure I have come across. I just fixed a Polaroid FLM1514 which has a 2956C Ver 2.0 power board driven by a Fairchild CM0765. Turns out the VCC capacitor was bad and not even swollen, sowpped it for a 47uF 50V and presto.
Mar 15, 2014 | Polaroid TLX-01911C LCD TV
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
Lg lcd plasma tv wont turn on and has no stanby light either
Check the tv power source like electrical outlet have power and work for other devices?Tries tv unplug,replug it back about an later for tv to do a resetting itself back to the factory setting.The tv now should be working again.If the tv still have the same problems,than the tv have a dead board that call the tv power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 18, 2011 | iLO 3200 32 in. LCD Television
I have a samsung lcd i have no video
Please replace power supply board in tv that is not providing voltage supply to back light inverter boards in tv, required power supply board is available discount-merchant.com
Click above link to view power supply board image and price info.
Thanks.
Mar 16, 2011 | Televison & Video
I have a samsung lcd ln40a330. When I try turning it on it does nothing. Is there a fuse to it.
Yes,the fuse in the power supply board,that the board,where the power a/c cord plug into it.Check ur power source?Yes,than the tv power supply board is dead.These modern circuit boards design never kill the fuse that easy.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Samsung LN40A530 40 in. LCD TV
After 10 minutes picture cuts off and off on switch flashes.
Check the power source?Yes,Power supply board is the problems,it dying.That the board on the tv,the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Aug 04, 2010 | Emerson LC195EM9 19 in. LCD TV
Tv doesn't power up
Check ur power source with other devices?Yes.than ur tv power supply board is dead.Replaced the power suply board will solved this problems.Tries wesites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 27, 2010 | Vizio VW32L 32 in. LCD HDTV
3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Dec 10, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
TruTech PLV1615T 15 in. LCD Television Logo
56 people viewed this question
Top TruTech Televison & Video Experts
Eric Rotmil
Eric Rotmil
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
