Question about Panasonic Viera TH-50PX80U Plasma TV
My panasonic viera tv suddently is not picking up
My panasonic viera tv suddenly is not picking up a signal
    Problem Solver:
  • 6 Answers
The most common reason for a digital TV to read "No Signal," or to constantly suffer from frozen screens is poor cable connections. First thing you want to do is to check to make sure they are all correct, and that you are using cables rated for your system. Next is that you want to remember that the fewer lines you use, the stronger your connection will be. If your connections are all good, check to see if you are using splitters. Imagine your cables are actually water lines. It would be easy to see how thin your flow will be if you have a half a different different directions and lines through which you are forcing it to flow. If you can limit the number of lines you have connected, then your signal will be stronger. There are often a number of different ways to wire a sound system and peripheral components to your home theater. Sit down and review it. Anyplace you can eliminate a line (or mess of lines!), the stronger your signal will ultimately be when it gets to your TV's receiver.
If you are using cable and none of this works, chances are you have a "leak" in your line somewhere which needs to be reviewed by your provider. Be sure to remove all splitters and all such diverting sources before they arrive, though, as if the problem is found indoors, you will very likely be charged for this as a service call.
Posted on May 09, 2010
Panasonic viera plasma 60 tv. Ethernet hooked directly from router to tv, how do I put router password into tv.
The router password will be asked for when you try to connect by the TV if the thing is picking up the WiFi signal.
Jun 24, 2017 | Panasonic Televison & Video
Suddenly displaying no signal
check the aerial is plugged in and that is in good order. If your tv is analog/digital, check that it has not gone to another source, there might be an option to put it onto digital output. It may not be too serious hopefully
Jun 01, 2015 | Panasonic 37" VIERA Full HD 1080p IPS LED...
I have a Panasonic Viera TV Model No> TX-L32D26B and suddenly have no signal for any of the BBC channels. What do I do?
Try reprogramming your set if you have not already. If that does not work you might want to adjust your antenna.
Apr 07, 2011 | Panasonic Viera TC-37LZ85 LCD TV
What type of cable connector should I use for my Panasonic Viera 32" LCD TV? My old tv uses a screw on cable connector. It doesn't fit my new Panasonic Viera 32 LCD.
The incomming broadcasting signal cable connector are been standard,since the late 80 til now,why doesn't fit,is a mystries to me.U have cable or satalite dish services wright?Call their customer service,they'll send out a Tv tech. to check it out for u.
Dec 14, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
I connected my 65 inch panasonic viera tv to my laptop but get a black tv screen, help?
If you are conected VGA cable set your TV to PC input. When you turn your laptop press fn then
f8 that should transfer the signal to the LCD.
Thank you
Dec 12, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have a panasonic viera plasma and suddenly have a 1' black line going down my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 15, 2010 | Panasonic Viera TH-50PZ800U Plasma TV
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera missing the red color spectrum?
Ours is doing the exact same thing! I came here hoping to find an answer. Did you figure your tv out?
Nov 26, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Volume suddenly turned down during commercial
shut off the all BBE and surround and the AL sound page 27 of the manual.
Feb 22, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-50PX80U Plasma TV Logo
506 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
