Question about Panasonic NN-T694SF Microwave Oven
PANASONIC INVERTER MICROWAVE, 1300 WATTS
The microwave is not heating and after 23 seconds of operation, it cuts off. It doesn't even get warm... it's only about three or four years old and is not used daily.
Light, turntable and timer all work just fine.
Any help you can offer would be most appreciated!
Many thanks,
JW
  • Anonymous Apr 12, 2008
    First, the circuit breaker kept tripping but once the circuit ws back on the microwave would work for a while. Then it started the cut off right after it started. It did this a few times so I unplugged it and removed it because I was afraid something worse would happen. I thought I would try it again. This time I noticed a weird noise and the inside light dimming. I think it's had it.
  • skibunnymama Nov 06, 2008
    Same thing with Panasonic Inverter 1200W, and is only 3 years new!
    Probably not worth repairing?
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Posted on Apr 11, 2008
  • Panasonic Master
  • 5,569 Answers
Listen for the cooling fan; if it isn't running, the unit may not be able to turn on as a safety feature.
Also; when it 'cuts off,' does the rest of the unit show signs of life still?
If so, it could be any number of internal failures, the magnetron itself, the power supply that delivers high voltage or the heavy transformer that supplies that section.
What you still have working is not dependent on that section.
I've noticed that many things are failing earlier than they once did; it comes from the pressure to keep prices down so we can still buy their stuff with decayed dollars.
Posted on Mar 28, 2008
  • Steve Allison
    Steve Allison Mar 28, 2008
    An add-on to the first message:
    After seeing several others with problems in that series, it started to seem familiar.
    I looked at many models while searching for one to replace our aging but working unit and found that many of the later designs utilizing invertors in their power supplies, were very prone to failure.
    This principle is similar to a PC power supply (I was intimately involved with these many moons ago during the early development) and certain components are very critical in them.
    Your unit is reviewed here:
    http://www.amazon.com/Panasonic-NN-T694S...
    You ain't gonna like what you find there.
    Sorry - but then, would anyone care to buy a Saturn SL2, purchased new, with about $4,000 worth of repairs and a blown engine at 57k miles?
    Some lemons don't make lemonade.
SOURCE:
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Panasonic NN-F542BF 1300 watts microwave switches off after 3 seconds
It sounds like you were sold somebody else's problem, it could be a bad magnetron, cracked high voltage diode, and a shorted high voltage capacitor to name a few. I recommend a professional if you feel it is worth getting checked.
Mar 09, 2012 | Panasonic Microwave Ovens
I have a panasonic inverter microwave model #nn-S540BFWR. What is the wattage on this model or where can I locate the wattage
The output wattage is 1100 watts. It can be found on the second page of the operating instruction manual. If you don't have one, you can download it at retrevo.com, just enter the model number and get a pdf of the manual. Hope this helps you.
Apr 19, 2011 | Panasonic NN-S540 Microwave Oven
Shuts off after 23 seconds....
In most cases when the microwave stops @ 23 seconds it's the Magnetron which has failed, and is shorting to earth.
Either that or the magnetron isn't getting the right signal from the inverter board. It gives it 20 seconds to get the right signal or it shuts itself off.
Apr 04, 2009 | Panasonic Microwave Ovens
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Faulty Panasonic inverter dimension 4 combination microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Oct 20, 2008 | Microwave Ovens
My Panaosmic microwave model number NN-S543 just stops after running for 23 seconds. It was running fine for the past 5 years and suddenly yesterday this problem starred. Even the 23 secconds it runs there...
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 05, 2008 | Panasonic Microwave Ovens
Sick Microware
first unscrew the unit replace fuse "near transformer this fuse is for the heating" --i think ur microwave needs a proper ventilation..
Feb 05, 2008 | Bosch HMT8625GB Microwave Oven
Microwave cuts out after 23 secs
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Panasonic NN-T694SF Microwave Oven Logo
821 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
