Question about Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor
My computer intel pentium 4 no sound.what should i do...????
    Scholar:
  • 103 Answers
After every installation of Operating System or formatting a hard disk, devices installed from your computer needs a driver for it work. In your case the audio/sound device, you need to install the audio/sound driver---it can be found with your motherboard cd, look for AUDIO DRIVERS, or if it happen you no longer have the motherboard cd, you can download it from the internet.
Posted on Jun 19, 2010
    Sergeant:
  • 258 Answers
I think you need to install 'RealTek Driver' for your operating system. Download that from internet for your operating system.
Posted on May 09, 2010
4 Suggested Answers
ericram
  • 101 Answers
SOURCE: Upgrading IBM ThinkPad T20 Intel Pentium III to Intel Pentium 4
Patrick, I'm glad to see your enthusiasm to explore and expand on your computer knowledge. Unfortunately I have to be the first to let you know that in this case your ideas on upgrading your systems by simply changing the processors just won't work.
First of all a Pentium 4 (or Centrino, which is the mobile version) literally will not fit into any of the systems you mention. All CPUs are made in specific form factors to fit into different sockets. Most Pentium 4 processors were made for Socket 478 or 478B sockets, which mean they have 478 pins on a chip roughly an inch and a quarter square. The high number of pins allow more signals and data to be passed simultaneously to the motherboard, one way the speed of the CPU operations were increased. Pentium III and older Celerons were mainly socket 370 chips on a chip almost an inch and three quarters square. The lesser number of pins were aligned in six concentric rows with a blank central square. Pentium II and even older Celerons used Socket 7 and any of a half dozen other schemes and were often put on daughtercards to make them somewhat interchangeable. It would be like trying to put a square peg in a round hole.
They also make other forms, like socket 775, 939, and the newest AM2, all of which are pin-incompatible. In certain situations there are adapters that will let you put a newer CPU into an older socket but the specific upgrades you mention have no equivalent.
There are other engineering factors to be considered as well. Not all CPUs run on the same voltage. Many desktop motherboards have been designed that are adjustable either by selecting the operating speed with jumpers (old style) or by electrically sensing the optimum speed of the CPU. Then there are the memory and bus speeds. The CPU has to be able to interact with the memory so they must share a signal speed. This is the Front Side Bus. Older Pentium 4 CPUs were designed to use PC-133 memory but more powerful CPUs. certainly any in the 2.0GHz and up range, are designed for Double Data Rate (DDR), which is PC-2100 up to PC-3200. The pin configuration of the memory is different also to reflect and optimize the faster design. Of course there is now a DDR2 design and most recently DDR3. Core-Duos and Quads use the DDR2 and DDR3 type memory.
Another factor is heat. Faster CPUs run hotter. the system must be designed to accomodate and release the greater amount of heat generated, thus there are larger heatsinks and fans and more vent holes. Otherwise the CPU would start acting erratically and eventually burn out.
Things would be slightly different if you were talking AMD chips, as the socket 472 was much more versitile and could handle a wider range of CPUs and speed, from Duron to Sempron to Athlon XP, all because of the way AMD designed their chips. Of course, they too had to upgrade to surpass physical limitations, leading to the socket 754 and other newer designs.
Desktop machines are much more flexible to upgrade because of the space available and the fact they are designed with expansion slots. If you need a higher video card to run games, or more com ports to run extra printers or whatever, you can generally place a card in a slot to add the functionality. If you reach the design limits of a motherboard you can usually swap it out. Not so with laptops.
Laptops in particular are hard to upgrade because everything is integrated into or designed to plug into the motherboard, which has to fit the case properly like a jigsaw puzzle. This is not to say it is impossible to upgrade somewhat, but usually for laptops it means putting a faster CPU of the same form. Here is an example that is specifically for the IBM T40 laptop:
http://bsnugroho.com/t40upgrade.aspx
No, if you want to upgrade to Pentium 4 or Core Duo or Core Quad speed and performance, you will have to go out and buy a laptop.
Please do not let this discourage your enthusiasm. You share the spirit of the old school to push the limits that has made all of these computer evolutions possible. Consider formal training to round out your knowledge and to expose you to more within the field.
Posted on Dec 31, 2008
bootz84
  • 197 Answers
SOURCE: Can i change a used processor on a other computer?
Check to make sure that both computers have the same socket type, it should be printed directly on the connection for the processor. If the sockets match, you should have no problems dropping the new processor in it. Incompatible processors simply won't fit in the motherboard, so if you can't seem to get the processor to fit properly, it's most like incompatible.
Posted on May 06, 2009
nonontech
  • 4737 Answers
SOURCE: hi my computer. Intel(R) Pentium(R) 4 .no sound.
Are you sure that there's Audio Driver? if not try reinstall the sound driver, that will solve the problem, I want to know whether you sound card is onboard or additional PCI sound card etc... if this isn't solve the problem refer to this article.. http://www.computerhope.com/issues/ch000208.htm Good luck and if you still can't help yourself do let me know in a little better so that i can straight away tell you the solution..
Posted on Apr 29, 2010
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
My computer is intel(R) pentium(R) 4 inside 3.00GHz,2.99GHz,0.99GB of RAM...... i lost my motherboard supporting CD..now i getting problem of sound after insatlled windows XP......please suggest me what i...
Hey there. Pentium-4's use AC97's Realtek sound systems, so you will need an AC97 driver.
Download it from : http://www.softwarepatch.com/utilities/ac97.html
Have fun :)
Aug 23, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel(R)Pentium(R)4 CPU 3.00GHz board software drivers
i loss my sound driver cd for window 7 intel (r) pentium (R) D cpu3.00hz software for me plz help me.........
Jul 31, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sound driver
You can download drivers from " http://www.dl4all.com/7r7/tag/Intel+PENTIUM-4+865GV+mother+board+sound+driver.html" and " http://www.intel-drivers.net/intel-pentium-4-865GV-motherboard-driver.html". Hope this will help you.
Jun 03, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel r pentium r 4 cpu 3.00ghz drivers
sir i have not sound driver. my computer is intel(r) pentium(r) 4 cpu 3.00ghz. windows= microsoft windows xp professional version 2002 sp 2 v.2096.which sound driver install in my computer? sir pls tell me somthing.
Oct 30, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I m using intel pentium 4 ht inside compaq presario sr5110il desktop pc with intel pentium 4 processor 641; my computer does not play sounds and giving the error that your sound card driver is not...
<span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">You need to download the Intel audio driver for your model </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">motherboard.</span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">You can download the motherboard drivers from Intel WEB site. </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">Select your model motherboard/device, and make sure you select </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">the Windows XP or Vista version of the drivers that matches your Windows operating system. </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt; mso-bidi-font-size: 12.0pt">Please click on this link and select your model motherboard : -</span><span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"></span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><a href="http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr">http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr</a></span>
Aug 25, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Display
Go to www.intel.com to download drivers for them.
Sep 30, 2009 | Intel Pentium 4 840, 3.2 GHz Pentium D...
Sound Driver install
i want download pentium dual core e5200 2.50GHz sound driver setup. plz help me
May 23, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Not accept sound driver
Either can be currupted driver software or can be CD.
Oct 30, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sound Card Drivers Intel PENTIUM-4 865GV mother board
i m using motherboard of intell pentium 4 can u help me for intallation of sound drivers or to download it thx zakir
Jul 07, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel Pentium 4 1.7G, 1.7 GHz (p41700400256sk478) Processor Logo
139 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
