Question about Epson Stylus Pro 10000CF InkJet Printer
Just purchased an Epson Stylus Pro 10000 Archival Ink. Nosel check looks good with solid lines, however prints are very light. Ran clean multiple times. Printer came with existing ink and I don't know if it may be because the ink is old (2 to 4 years per cartridge) or if the head needs cleaned. Or...?
    Brigadier General:
  • 4,090 Answers
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
Posted on May 09, 2010
Epson 10000 not printing cyan and black
Take the inks out and put them back in. May have got unseated. Check for foreign objects which may have jammed the heads.
Jul 08, 2016 | Epson...
Tip
Epson Stylus pro 10000 Vista x64 Compatible? YES
Use the driver for the next model up: Epson stylus pro 16000.  A 64 bit driver is available for XPx64 on Epson site:  http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=19156&prodoid=22966689&infoType=Downloads&platform=All Install Printer Driver v5.50 in Vista x64.  The 10000 will print 100%, just like in XP with its own drivers.  Any problems?  I would happy to help you save the time I spent before finding that out.
on Apr 05, 2009 | Epson Stylus Pro 10000 InkJet Printer
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
How to fix blue nozzle
Beings there are to "cyan" color heads, light cyan and regular cyan, your question makes little sense. Either way it sounds like both print channels are clogged so you are getting no clue output at all. FIrst check your cleaning pads and the parking pads. They are worn out or dried out by now most likely. One way to help the cleaning Process is to actually push the printhead into the pads when it is running a cleaning cycle. The idea is you want to get a pressurized line so its pulling maximum ink thru the lines. This often clears up many light clogs.
Jun 20, 2014 | Epson Stylus Pro 10000 InkJet Printer
Re: C84 I'm using generic ink, but the red
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Nov 12, 2009 | Epson Stylus C84 InkJet Printer
After multiple head cleanings one color still does not print.
Please explain your problem. Do you get a good Nozzle Check? Do not do a bunch of cleanings...you might be just wasting ink.
Nov 11, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson 10000 printer colors not printing
I am gonna gusess there is a break (or poor connection) in one of the lines in the flexable cable that feeds power to the print heads. You might try checking the continuity of each line.
Sep 12, 2008 | Epson Stylus Pro 10000 InkJet Printer
EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Archival ink for epson 740i?
Great question and one I handle for Professional Photographers here in my area.
First of all, are you working in a museum environment or not or another type environment where chemistry of the paper needs to e controlled because of what it emits when decomposing, or is this an issue of the paper and ink being exposed to flash photogrpahy, klieg lights, or UV -A or B sun rays?
To what factor is cost involved?
Regards,
Worldvet
Jul 11, 2008 | Epson Stylus Color 740i InkJet Printer
Epson Stylus Pro 10000CF InkJet Printer Logo
209 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
