Question about LG LB1200ER Air Conditioner
My lg a/c only blows air with no cooling what is
My lg a/c only blows air with no cooling what is the cause
  • 88 Answers
Possible a tstat problem or compressor is not coming on...put your ear by the ac unit...if you hear a buzzing noise ,then shuts off,humming...compressor not coming on...
Posted on May 10, 2010
What causes a packaged air conditioner/heating unit made by lg to blow cool air on high heat
It sounds like your heat kit isn't large enough for the cfm's provided by the air handler. Or you may have lost a heat strip or two
Feb 10, 2017 | LG Heating & Cooling
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Why did my ac quiet blowng heat
Check the controls, this unit most likely a reverse cycle air conditioner. It can be set to cooling or to heating. The conpressor is reversed to heat or running normally to cool.
If it is not then the compressor is not working and it is just blowing room temperature air.
Apr 03, 2012 | LG Heat cool Window Air Conditioner
My air conditioning unit just stopped blowing cold air today. It is a window unit, i'm not sure of the model number, but it is an LG.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Sep 22, 2011 | LG Heating & Cooling
My LG Model LP6000ER blows cold air for about 5 minutes and then the compressor shuts off
heatman101
Jul 10, 2011 | LG BP6000ER Air Conditioner
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
heatman101
Jun 27, 2011 | LG Heating & Cooling
I have an LG F12HJ SPLIT ROOM Air conditioner thats not blowing out cool air.
Air Conditioner Trouble - Review the Possibilities
heatman101
Jan 25, 2011 | LG Heating & Cooling
Does not blow cold air
check your compressor first to see if it comes on, then the freon inlets and outlets. one side should be hot or warm and the other should be cool or cold. If not 1. check the fan or blower for the cooling fins to see if it is blowing. 2. call your manufacturer to see if a capacitor or switch could cause the apparent problem (either the cooling fan not blowing or the compressor not coming on) . this info is for a house a/c but should not be muich different
Jun 09, 2010 | LG GL6000ER Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
No cool air
sorry but you will need to have your freon levels checked and have them check all freon connections checked some times a vibration or a bump is enough to cause a leak
Apr 11, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG LB1200ER Air Conditioner Logo
250 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
