Question about Westinghouse Microwave Ovens
Canopy Range hood WRF600CS Diameter of flexi duct?
  • inge_hagen May 09, 2010
    thank you for your answer
    Inge
  • 8,197 Answers
The hood uses a 6" round duct. I hope this has answerd your question. If not please ask some more.
Posted on May 09, 2010
Canopy
no it cannot be replaced you have to buy a brand new one srry but have a nice day
May 14, 2012 | Jenn-Air JMC8130DDS Microwave Oven
Ge spacemaker xl-1800 microwave shuts off if used longer than 3min.
That would be model "JVM1540SM1SS".
This is due to overheating of the magnetron.
Attached to the magnetron is a thermostat, which opens to interrupt power if the heat gets too high. Then when it cools, the thermostat closes, restoring power.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 02, 2010 | GE JVM1540SMSS Microwave Oven
Hi. I want to replace my Daewoo KOT 210UW over-the-range microwave. I need to know the size of the hood opening. How do I find this information?
All over the range microwaves are 30 inches. All the ducting is the same also. So you can replase with anyone you would like.
Dec 28, 2009 | Daewoo Microwave Ovens
My Microwave, Kenmore 721.62464201, is arcing from the upper right side. Now there's a hole in the side plate called the canopy. Do I need to replace just the canopy or is there something bigger wrong? ...
Just replace the canopy. This is a common problem with the layered mica canopies. Moisture gets in between the layers, the microwaves arc across the moisture and burn holes and bubbles in the canopy. Good Luck, Appliance Specialists
Dec 16, 2009 | Microwave Ovens
Need assistance installing a JVM1660BB range microwave oven. How do I attach the sleave to the duct to the microwave, while mounting the Microwave on the wall. Thanks for the specs on the microwave oven....
From page 14 of the installation instructions online here:
"Extend the house duct down to connect to
the exhaust adaptor.
"Seal exhaust duct joints using duct tape."
Jun 06, 2009 | GE JVM1660 Microwave Oven
How to find rectangular to round transition adaptor
They used to sell them at sears. Its a common duct item for vents. Try home Depot.
Jan 13, 2009 | Samsung SMH7178STD Microwave Oven
VENT NOT SUCKING
I would suggest checking the filters, checking the duct work (including the outdoor vent) and if that doesn't turn up the problem, the hood vent exhaust fan blade assembly may have come loose on the shaft.
You can download GE owner's manuals and installation instructions here to help you verify the filter status and duct work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Installation
I just took out the range and made an outlet out of the existing wiring.
Jun 25, 2008 | Microwave Ovens
Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at http://www.wehaveparts.com or Vance Baldwin at http://www.vancebaldwin.com You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Dec 13, 2006 | Panasonic NN-2505A Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
