Question about Samsung SH-S202J 20x DVD?±RW DL IDE Drive DVD±R Dual Layer Burner
MY DVD-RE IS NOT READING ANY CD OR DVD..WHEN I M INSERTING ANY DISK IT KEEPS ON READING IT
    Brigadier General:
  • 4,090 Answers
Try using a Iris eye cleaning disk. Mosxt times when constant reading occurs or it says no disk it is the iris inside that has become occluded with dirt. Checkl that there are no finger marks on the disk and it is clean too
Once you have run the cleaning disk use a non scratched clean disk to check its load and read ability before trying in the disks that you had trouble with.
If they still give trouble then the problem will be with those disks and not the laser in the unit.
Please rate my help++++Thanks for using FIXYA
Posted on May 09, 2010
My LG DVD Writer is not reading any disk when i am inserting the disk in Drive. IT stops blinking also.
Hello Ammit,
It seems that the lens of the DVD writer is not working properly. Please try to clean the lens of the DVD writer with help of CD/DVD lens cleaner disc. The lens cleaner disc is easily available in market. After cleaning the lens try to run the CD/DVD again
May 08, 2011 | LG (GSA-H42NK) Burner
Has a disk with error message will not open manually or with remote
Try inserting a DVD, a CD or a VCD to see if it happens to all disks.
- If it does, the Lens might be dirty and it's having a hard time reading the disks and you'd need to use a Disk Cleaner.
- if not, then the disc might no be supported by the unit. Check with your manual to see what are the supported disk format. (Is it RW+/- or R+).
Let me know what happens.
Feb 08, 2011 | Toshiba D-VR5 DVD Recorder/VCR
Does not recognize disk
Either:
* the disk you're inserting is not "empty" -- try it on a different computer;
* you should try a different manufacturer of "blank" disks;
* you need to upgrade the "firmware" inside your CD-writer, to recognize more brands of "blank" media;
* the CD-reader is malfunctioning -- when you "cancel" the burn-attempt, and insert a commercially-produced program CD or commercially-produced audio CD, can those disks be properly read?
* you have two CD/DVD devices in your computer, and you're inserting the "blank" disk into the "wrong" device.
Jul 18, 2010 | Yamaha CRW 2200E CD-RW Burner
Technics 60 cd changer cannot see disk in changer
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the CD Changer not reading discs is a bad drive. The following website sells the drives and does installs:
http://store.richspsxparts.com/wiiredvddr.html
This drive should fix any reading issues you are having with your disc, or issues inserting your disc or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your CD Changer.
Hope this will help...
May 26, 2010 | Technics SL-MC70 60-Disc CD Changer
Dvd not open any dvd
the laser has gone inside the drive... it will be much cheaper to buy a new one :)
thanks
alex
May 06, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
Combo Cd/Dvd Drive is not reading Cds nor DVDs
1. Remove your burner from your computer then open it by removing the screws under the burner.
2. When the cover has already been removed, get a cotton bud then soak it in alcohol to clean the lens. Because the lens might just be dirty. Then after that put the cover back by screwing it again then install it back to your computer.
Apr 08, 2009 | LG GMA-4082N 8X SLIM DVD RW DRIVE FOR...
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Transfering my video tapes to DVD
A couple of quick observations: -If you have two or more optical drives you could be inserting the disk in the wrong one. -You may have just misspoke when you said *insert into the DVD/CD burner drive a CD-R disc* but just to make sure you need to be inserting a blank DVD disk and not a blank CD. No offence intended, especially since I?ve made both of these mistakes in the past myself :)
Jan 02, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Samsung SH-S202J 20x DVD?±RW DL IDE Drive  DVD±R Dual Layer Burner Logo
178 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
