WS 55819 Mitsubishi HDTV , the tv turned off itself. The power light on for couple of second then off again. What is wrong with the TV?
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
http://www.retrevo.com/support/Mitsubishi-WS-55819-TVs-manual/id/276bh851/t/2/
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55819.pdf
http://service-manual.eu/model.php?id=2703
Above, a service and repair manual, above that are two user manuals.
Posted on May 09, 2010
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Feb 17, 2010 | Mitsubishi WS-55819 55" Rear Projection...
WS-55819 TV, about 8 years old, stopped working. No picture, just black. When trying to turn on, power light appears for a couple seconds, then turns off. No other indications of life. My kids...
DO THE SELF CHECK YOUR SET HAS:
When you turn it on and power light goes off in a few seconds;
On the front of the set push and hold both the Menu and Input (Device) buttons for at least 5 seconds and release both.
Power light will then blink a two digit code, most common is 2 blinks, a pause and 2 blinks--it will repeat the code at least 5 times.
Let me know what code you find and I will tell you what it means and maybe what is wrong with your tv.
I hope you find 2,2, as that is the most easy to fix.
If this helped you rate this solution as I do this here for free.
SD TECH
Jan 14, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 HDTV won't power on
At the very least you are not getting any of the Standby power to the Microprocessor (5 vdc). I would concern myself with that area once you get the manual. In the mean time check all the fuses.
Dec 01, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819 power problem
Hello DaveDaveDave, Ok let's levelset as is said in the business world today. it looks like you have an overcurrent protection problem which means that the tv set has a component that is causing excessive current to be drawn. Now this can be caused by a component withc has become "leaky" (by leaky this means the inability to prevent the flow of electrons as related to dc voltage). Your last statement is the reason I am replying how I am. Since you don't have equipment your only option is to take this set to a TV repair shop and have it repaired. I have given you a possible cause a component in the HV section that may have gone bad, but without substantial data as to the voltage levels and signal appearances, one can only guess. I hope this helps and you find what you are looking for. Thank you, Shuttle83
Aug 12, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
