Question about Samsung Televison & Video
My t.v has a lilltle screen in the coner.how do i get it off
  • 8,197 Answers
The little screen in the corner is the Picture in Picture. To remove it on the remote you need to push the PIP button or the Picture in Picture button. Or give me the make and model # I will tell you the step by step process.
Posted on May 09, 2010
42 plazma screen has square at bottom coner has all colores in it
In order to try to help---take a good photo/s and either post it here or somewhere with a URL (location) so I can see what you have.
Mar 25, 2012 | Samsung PN42B430 42 in. TV
Tip
But I can't do it follow chuck's advice. You know I am a lilltle stupid about...
First you will need to make a list of parts that you will need to get. Definitely get a new belt (dont use an old one that has been laying around for years they crack, split, and fail quickly) take the brush roll nozzle off and inspect the fan for chips, and cracks around the center. Replace if necessary. Next remove the brush roll, it must spin freely replace if it feels tight or makes noise. Now as long as the vacuum worked before, those three things are what you could need (plus any broken parts). Now that we have the parts we can get started. remove the bag, handle, scuff plate and cord. there is a release button for the handle. The plastic mini emptor on the bottom of the bag rotates away from the body and lifts off. And the scuff plate pops off using a flat head screw driver in the center slot and prying up. You will see 2 screws under the scuff plate and two screws in front on the top, remove those 4 screws and lift top cover off. you will now see the inner workings of the motor.
If you need to replace your fan take out the other screws in the front, there is two under the top cover, two towards the bottom, and one more near the center. hit the bottom of the aluminum cover with a rubber mallet til it pops off. there is a spot near the back of the motor where you can insert a wrench to hold the motor shaft. use a pick to twist off the front spindle (left hand threads opposite from normal) remove and replace fan. use a small bead of liquid gasket to seal the compartment and install screws. (it helps to have a piece of 2 x 4 to set the machine on and install the front cover.
Now we will move to the motor compartment. First, vacuum out as much of the fuzz and dust out of the inside as possible being careful not to disconnect any of your wires. You can also blow it out make sure to blow through the motor to get all the carbon dust out. The cleaner you get everything inside the better. Next inspect your motor carbon brushes and commutator for wear. If that is good spin the front shaft, listen for bearing noise and feel for stiffness. If the bearings feel bad then you should rebuild. inspect the transmission gear, motor gear, and belt for wear. replace if necessary. (kirby recommends that you replace all pieces at once because if you only replace one, the worn parts will damage the motor and transmission internal parts) Now apply some 3 in 1 oil to the top slide where the handle connects. Do Not Disassemble! there are way bearings in the assembly and if its not assembled right the self propelled system will not work properly. Move the assembly back and forth to ensure that all of the way bearings receive oil. Now you can reinstall the top cover, cord, scuff plate, and the bag. The brush roll nozzle, clean all hair and twine off brush roll if you are using the same one. Slide a new belt over the brush roll. make sure to clean and wipe out the nozzle. The brush roll can only be installed one way, one of the end caps are bigger. They should always be numbered with 1 to 3 new brush roll gets set on one and you can rotate higher numbers for more wear. install brush roll rotate belt hook and install nozzle. Plug it in and take it for a test drive. You have now successfully serviced your Kirby Generation series vacuum. Kirby recommends this be done once a year.
on Jan 18, 2010 | Vacuums
Screen has dots and lower right coner is blue
thats bad the optics assembly must be replace . Its expensive.
Oct 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Black screen
you may have broken lcd screen it just my have small crack on the coner
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
There are extra stuff on my y= function
Try turing off the Inequalz program:
APPS
scroll down and select: Inequalz
Select Option 2: Quit Inequalz
Aug 18, 2009 | Texas Instruments TI-84 Plus Calculator
Leaks in coner
you can patch the leak with some marine epoxy from any hardware store or also some weldit.
May 02, 2009 | Goldstar DH304 Dehumidifier
Ice box remove?
no that was put in there by the manufacture u could but u would damage the refreg
Nov 27, 2008 | Whirlpool Refrigerators
93 Ford Escort Wagon 13" wheels
hi there there probley is no diffrence but make sure they dont rub or scrape if they do u can go lower profile tyres but it may also put you speed o out a lilltle bit
Jun 30, 2008 | 1993 Ford Escort 4 Door
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
