Question about LG BG8000ER Air Conditioner
Not cooling properly. dismounting the front panel showed formation of ice on ac tubes
    Novelist:
    Champion:
  • 246 Answers
Ice forming on the evaporator coil (you called it ac tubes) is a common sign of 'low' air flow across the coil.
The evaporator coil will 'ice' if the air flow is restricted.
This usually happens when the filter and or coil becomes dirty.
If the filter is changed often (when dirty) then the chances of the coil becoming dirty are reduced.
In any event - you must have a 'clean' filter and a clean coil.
The filter is usually made to be 'washed out,' and the coil can be cleaned with a wrag - or brush of some sort.
The goal is to make sure the filter and coil are both clean.
Other things can cause a coil to 'ice,' but are less likely.
a) low on refrigerant - not likely because the system is 'sealed' and the chances of losing gas are remote unless it's an older AC and has been 'opened' in the past - which improves the chances of a leak.
b) a problem with the fan motor - i.e. cutting off and then back on - or - not running as fast (both will reduce the air flow) as it should because of internal problems.
c) in a room with a 'low' load - i.e. the outside temp is low and the room is cool - thus causing a low load situation. This too is not likely as most AC's are being run because it's hot in the room.
Bottom line - is I would make sure my filter and evaporator coil are both clean and unrestricted.
good luck!
Posted on May 09, 2010
Compressor and fan working but it is not cooling
If everything is fine, check whether the door is closed properly. There may be some vent while closing the door.
Oct 29, 2012 | Refrigerators
Air is not blowing cold ice on coils
Air conditioning is all about the proper airflow across the condenser and evaporator coil (coil panel). Be sure your filters are clean and there are not any obstructions such as a dirty condenser coil. Also check all tubing and fitting connections for signs of oil which would indicate a refrigerant leak and has now caused the AC to be insufficiently charged.This would cause ice build-up on the evaporator (coil panel) and the out-put of only 70 degrees.
May 31, 2012 | Frigidaire FAS156N1A Air Conditioner
I have a sanyo ac which was working very well. after that it became to start sound then after cool air have gone and ice is showing at the front. what is problem. how much money will take to cure it.
If it is a window unit and it is freezing, then it is likely a capillary tube restriction. For parts and labor you would probably pay around $200-300. If the unit is under warranty, they should just send you a new one free.
Aug 14, 2011 | Heating & Cooling
1999 GMC Yukon. Rear AC cooling great. Font AC not cooling as well. Replaced orfice syphon tube, vaccumed down and recharged with 2lbs R134a. Checked front temp controller. All checks ok. Front AC still...
If the rear is working well and front is not I would suspect a blend door or actuator issue in the front.Double check and see if you can hear anything moving when you are adjusting temperature from hot to cold.Also check and make sure the air flow moves properly from defrost to vents and floor etc.
Jun 12, 2011 | 1999 GMC Yukon
Kenmore AC, no cold air
If the evaporator tube is iced up entering the coil and cool to warm leaving the evaporator, that would indicate low on refrigerant or a restriction. If it is iced up entering and leaving the evaporator, then, it could be low on refrigerant,blower not running at proper speed, dirty evaporator coil or filter.
You need to check the suction and head pressure and temperature to determine problem for sure.
Jun 07, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
I have a RUUD RCBA-3765G Coil. When my AC stopped cooling I went to the basement and opened the access panel. When I looked at the coil it was frozen completely, the insulation was frozen to the front of...
This could be caused by a low refrigerant charge or dirty filters restricting the airflow. Also it will happen if the indoor fan isn't running.
May 02, 2010 | Heating & Cooling
1.5T Voltas Vetris window AC. Ice formation
I think the more likely problem is that the unit is slightly short of gas\ refrigerant, which is a common cause of icing up evaporator coils and this sound you describe. First check that the air filter is clean. Another cause could be the defrost sensor is faulty, but I would think not. Some ice isn't actually a bad thing, but quite common as long as it doesn't form over too much of the coil, or get too thick.
Aug 15, 2009 | LG Heat cool Window Air Conditioner
Manufacturing defect in samsung air conditioner
ice formation in front portion of window ac. not enough cooling effect.
Sep 07, 2007 | Heating & Cooling
LG BG8000ER Air Conditioner Logo
228 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
