2006 Audi A3 Logo
Anonymous Posted on Apr 26, 2017
2006 Audi A3 - Driver side button for the passenger window is broken. From the passenger side, pressing the window button makes it move up and down no problem what so ever, but from the driver side, the window only moves down, nothing happens when I try to close the window, I know from the older models the A3 had a window problem where when the button is pressed, the window moves up slightly, then moves back down, but this is not the case here, as it does not move up at all. The window motor works fine as passenger window button works perfectly. Please help Thanks.
Marvin
Level 3:
Top Expert:
  • Audi Master 85,242 Answers
  • Posted on Apr 26, 2017
Marvin
Audi Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29058923
Points
266281
Replace the driver side window switch panel
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Feb 10, 2009
SOURCE: audi A3 2006
there is a square plastic box on the right hand side of the car under the bonnet, there is about 4-6 screws around the box , remove them , pull at the top section and it will come off,replace filter and replace screws, make sure all plastics are replaced , ant it is a good idea to hoover out box when filter is removed .
Anonymous
  • 43 Answers
  • Posted on May 29, 2009
SOURCE: Electric Window move slowly
Your window clips that hold the window in have broken.  You will need to replace these clips in order to fix it right.  The clips you can buy at any audi dealer.  Ask for the most updated ones.  There have been many updated clips.  Audi has been trying to develop better ones for years but they still keep breaking.  Its a very common issue.  Your window will still go up and down but since the clips broke you will have it bind in the track. To get you by for the time been.  Lubricate the window track with some silicon spray.  This will help keep it from binding up until you can do the repair.
Anonymous
  • 70 Answers
  • Posted on Jun 28, 2009
SOURCE: Driver side power window does not move up
the cable that drives the window up and down the regulator has broken. common problem. regulator needs replaced
Anonymous
  • Posted on Sep 26, 2009
SOURCE: AUDI A3 intake flag motor
I had the exact same problem. The check engine light would come on then go off. I didn't notice any drivabiltiy issues. End the end I had to replace the flapper motor, the high pressure fuel pump and the camshaft. They showed me the old parts and sure enough the camshaft lobe was worn down and the cam follower that actuates the fuel pump was in pieces. Needless to say it was very expensive. It's been a problem posted on many Audi sites. I went ahead and had the timing belt changed. Now she's as good as new.
Anonymous
  • Posted on Nov 01, 2009
SOURCE: audi a3 2.0 litre fsi cylinderhead problem
ginorini, get back to me on my email if you still have this broken head. [email protected] thanks alot
One of the rear doors on my 2006 Audi A3 keeps setting itself to child's lock, so the door remains unlocked on the outside. What should I do?
You may have to replace the lock module on the door or the switch on the driver's side that locks the windows if they're connected to the child lock? Normally the child lock is a manual lever on the inside edge of the opened door.
Check your owner's manual. If the physical lever keeps moving you'll have to get inside the door and find out why it won't stay in position.
2answers
How do u know if its d regulator or motor that goes out on a window. If d rear passenger on a 03 Audi a 4
If you can raise and lower the window by hand, then it's the regulator. 9 times out of 10 it will be the regulator. I have a 2003 A4 and both rear window regulators are broken.
I have an Audi A3 y reg the passenger side front window has stopped working. Which fuse do i change ? or do i do something else.. Thanks
please explain what a Y reg is please ,anyway i think you will find the fault is connected with drivers side master switch if the contacts go in this switch you will loose all control of the window including the passenger side control as no feed is passed to the other side of the car .
35helpful
4answers
2006 Toyota Avalon- Changed the battery and the driver side button to roll the passenger side window down doesn't work. The remainder of the buttons work, just not that single button. The passenger side...
try going to passenger door window switch and reset it by going down and holding for extra 3to5 seconds after window is down, do same to go up, then try doing it with master switch don forget to hold it longer, this is a reset also used on Scion vehicles, hope it helps.
Good luck
2helpful
2006 Audi A6 Avant Drivers window control panel
Replace the switch. It has lost connection to the up position.
30helpful
2answers
Passenger window won't work using the driver side control switch
Open the window with the local button and keep the button pressed for 3 seconds after it has fully opened. Then close the window and keep the button pressed for 3 seconds after it has fully closed. This calibrates the position of the window which it lost when you changed the battery. Good luck
1helpful
Passenger side front windscreen wiper does not move
yes, they have little teeth on them which are probably worn down. have to replace it.
Passenger electric window switch broken on drivers side,press switch on passenger side up or down window dosent move,does it need to have the wiring altered being as the switch on the drivers side is...
The main control switch on the driver door may need replacing, first check and see if the wires to the passenger control on the main switch is properly connected
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
