Xerox printer and windows vista
Xerox workcentre pro 416 S and my computers are all now vista except one
  • 3 Answers
Use workcentre pro 265 drivers. worked fine for me and is embedded w/ the vista os.
Posted on Sep 24, 2008
    Problem Solver:
  • 7 Answers
I also use the workcentre pro 265 drivers. it allows me to print from all 3 trays and the bypass just fine.
Posted on Feb 09, 2010
  • 239 Answers
You might have some luck using windows 7.
some drivers are available in 7 and not in vista.
Otherwise, there is not Xerox support for this model. You need to buy a new Xerox machine, but first find out what current drivers are available even in windows 7. Do not count on windows 7 64 bit. Windows 7 is still junk, no matter what they say about it, it is a pig with lipstick on it.
Posted on Nov 18, 2009
    President:
  • 2,072 Answers
I have looked into this . There is not a driver for that product.
Xerox also lists it as a "legacy" product, which means they do not activly market, nor provide phone support for, and therefore will not be writing a Vista driver for the machine.
I am not sure of a Third party Driver is available.
Wish I had a better answer for you.
Posted on Mar 28, 2008
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Need to reset replace drum message on Xerox Workcentre Pro 416
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Jul 01, 2009 | Xerox WorkCentre Pro 423 Copier
Unimessage pro driver error
try reseting the nvram. if no luck after that try changing the image control board.. with another one if it's avaliable.(maybe you have another machine around. If not then conect your printer to the network reset the printer so you can get an ip address.. usually it's a 192.168.*.* Then type that ip address 192.168.*.* into the top of your web address bar and you should be able to see you printer. If not i would change the image control board because it might be bad.
Feb 10, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Vista printer driver for a Xerox Workcentre Pro 635
try this....
http://www.xpvistasite.com/workcentre_pro_635_12490.htm
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    399 people viewed this question
    jasbo
    jasbo
