Question about Bose Acoustimass 15 System
No bass from the sub box on the bose accustimass 7. There is no seperate bass input. I tried taking the bass output from the amp to the center speaker input but that doesn't work
  • 57 Answers
Your bass box woofer driver is bad. Need to replaced the driver board. There no easy out.
Posted on May 09, 2010
How do i hook up bose accustimass speaker to my radio?
Acoustimass speakers need to be driven by a Hi-Fi amp/receiver or AV receiver. So the thing that's driving them needs to be an amplifier.
Unless your radio is also an amplifier then the radio and the Bose speakers are not directly compatible. There's no suitable output on the radio that generates the correct signal in sufficient power.
Sep 07, 2014 | Bose Acoustimass 5 III System
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
Adding Subs to a Bose 901 system
The Bose system has sound that is unmatched, the 901 with the equalizer is amazing. I have done what you are thinking of doing, the speaker runs 5ohms giving more power to the coils, adding a sub will color the sound and will not give the desired results, the 901 equalizer may be damaged with the modification of the sub, not recommended.
Mar 06, 2012 | Bose 901 VI Main / Stereo Speaker
B&k avr 7 with SACD inputs needs independent tone equalization settings
For your stereo configuration, refer to the preamp they are connected to for tone controls.
For your center and surround channels, refer to the B&K setup menus for those controls.
Feb 04, 2012 | Denon Audio Players & Recorders
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Bose Acoustimass 15 System Logo
748 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
