Question about ASUS P4P800 SE (890552603657) Motherboard
Lan terminal not working
Ethernet controler not detecting conection to modem reads driver but not conectivity
    Guru:
  • 825 Answers
First check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
Posted on May 09, 2010
Why Thinkpad T23 2647 4MP can't conect net after installed windows XP?
I do not use an automatic driver detection program, because they have a tendency to install the wrong drivers.
I look in Device Manager, and use the driver that matches THAT device, the O/S used, and is the newest version, (Date), with all the bugs worked out from an older version.
For your laptop that would be;
Ethernet Driver for Intel PRO/100 VE LAN that is the 49675 version, and has the date of November 8, 2002,
http://support.lenovo.com/en_US/downloads/detail.page?DocID=DS002672
Regards,
joecoolvette
Jan 28, 2012 | IBM ThinkPad T23 2647 Notebook
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Can you tell me what the difference is between the modem part for ethernet/usb adsl modems, 060-E240-061 AND 060-E242-A01. I would appreciate and info or direction to a specific web site for this info....
when your pc conect with ethernet port also say that LAN port and oter port is USB port
which one conect with ethernet/LAN port is
called ethernet Modem and which conect with
USB port called usb Modem.
Jul 06, 2009 | Computers & Internet
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
No LAN conection displayed in network connections
check that proper driver is installed, in the device manager that shows excmlatory mark that indicates proper driver not been installed, update the driver it will works
Mar 22, 2009 | HP Pavilion a6547c Refurbished AMD Desktop...
LAN not conecting
remove ur lan card and clean it and install it
Jan 21, 2009 | Acer 91.AB370.001 Network Adapter
Wireless internet not working contacted perlico and they said that lan port was not open
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
Nov 04, 2008 | Siemens Computers & Internet
When modem is conected through router computer not recognizing internet connection. with or without modem bridged
Go to Control Panel -> Network connections make sure the Local Area connection is enable. if this working fine then replace you LAN card. LAN card is connected to the PCI slot of the motherboard. And install drivers for your LAN card. Thank you
Sep 06, 2008 | Computers & Internet
Modem conection
In order to troubleshoot this problem, I need the following information:
Are you using a router?
What OS do you have?
Does your modem have a steady "online" light?
What IP address is coming up in ipconfig?
Oct 03, 2007 | Computers & Internet
ASUS P4P800 SE (890552603657) Motherboard Logo
708 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
